Question about Fisher and Paykel Washing Machines
We have a GWL15 Ecosmart washer which after having some issues with pumping out water and spinning up has stopped powering up and lighting up after we could smell something electronic smoking. We have opened it up and there is power running through the computer and we checked the 7 leads running out of the computer to the display panel. All 7 leads are hot and we were wondering if this is correct, and then most likely its the display panel that has burned out or if that indicates that the computer itself is shorting.
  • lazerousz Jun 24, 2009
    Now this problem started with issues spinning out and not draining, could the pump have short circuted the main board, I ask because I want to make sure that if we do purchase a new board that it won't happen again?
    Very much so, it helped to confirm what we suspected
  • 15,935 Answers
This is a timer issue - and in your case, the timer is part of the main board and not seperately serviceable.
CLICK HERE for a replacement board.
Thanks for using FixYa!!
Posted on Jun 24, 2009
  • blueextc3221
    blueextc3221 Jun 24, 2009
    Yes - then you will want to check/replace the motor - as it most likely burned a winding to ground causing backfeed to the board.
    From the added weight of spinning while full of water - your motor has undergone extra stress.
    You can check it by removing it and trying to power it up on your workbench without load - or have it re-build/checked at a local repair shop.
    Thanks:D
Water pump can't stop running once the power is on. Washer is working good when the water outlet is manual block and release
The motor controller boards needs repair.
The part that controls the pump is locked on.
You need a technician to replace this part.
Jun 11, 2013 | Fisher Paykel EcoSmart GWL15
GWL15 fisher and paykel stops mid spin
If the only light on was the spin when it was beeping,
That is fault code 1
1. (00000001) Motor Control Module Fault
The Motor Control Module has encountered an error when writing to an EEPROM address.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 18, 2013 | Fisher Paykel EcoSmart GWL15
I have a FP ecosmart gwl15. The electrical switch on diverter valve will not open to allow water to spin out
This is normal how this diveter works.
Gets hot to divert water over the bowl and cold to pump water down the drain. your machine is working great.
Oct 11, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
I put heavy wool items in my ecosmart Fisher & Paykel washing machine (approx 9 yrs old) and after it filled with water and drained the water, it beeped unbalance so i added something else to balance...
You should not continue to run the machine until you rectify the issue with the pump. Check the resistance of the pump's coil. It should be 7 ohms for the model GWL15. If the resistance is different, there is a problem with the pump electrically and it needs to be replaced.
Jan 12, 2011 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Fisherpaykel gwl15 washer will not pump down
remove as much water as possible lean washer back against wall ..pump twist locks into bottom of tub remove clamps with fingers pump will twist out no tools needed!!!! clean pump and retry
Sep 09, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
