Question about Gateway T-1631 Notebook
Laptop will not start past loading bar.
When i go to start windows, the error window recovery pops up. i've tried to start in every mode but every thime, the same thing happens, the loding bar pops up then a blue screen flashes & it restarts. i've tried doing a system recovery but, no luck. i'm thinking it's a failing hard drive. any suggestions?
  • Gateway Master
  • 32,281 Answers
To check if the hard disk is faulty, check the BIOS setting to see if the hard disk is detected. The BIOS may have a hard disk diagnostic utility, if so run the diagnostic.
Another way to check the hard disk. Remove the hard disk and connect it to an USB hard drive adapter, then plug it into a working computer's USB port. The computer should detect it as an external hard drive and if you can see, open the folders and files then the hard drive is OK, if not then you need a new hard drive for your laptop.
Posted on Jun 24, 2009
Toshiba satellite problems L775 can't get past "windows is loading files"
First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 03, 2013 | Computers & Internet
Laptop won't load past windows start up page
Keep pressing F8 before Windows logo and there will be an option to rset, but you need a recovery disk.
Jan 13, 2013 | Dell Latitude E5400 Laptop
Downloaded a Internet explored 9,windows home vista basic, turned off to restart.now won't go past window error recovery screen,go back n forth between ,load bar,to,safe mode,safe mode command prompt...
If you have windows vista installation disk just repair by system restore. Get try from safe mode or press F8 and use the option most recent setting. If this doesnt solve then contact your engineer to repair windows......
Mar 12, 2011 | Acer Aspire (AST180-US340B) PC Desktop
Was working fine.... power whent out at house.... upon startup after that it would say windows is loading files..... then the windows bar with moving light along bottom then..... mouse on blank background...
Try booting it into safe mode by intercepting the boot up when the first screen comes up by hitting either F8 or F2, depending on your system. If you can't get in to windows this way, insert the cd that came with the computer, or a windows cd, and enter in to recovery mode. If you have the option to do a system restore, try that, you will not lose any file this way. If you can't do any of the above options, then a full system recovery is your only option. Do a google search for any errors or error messages that are popping up to specifically target what is happening with your system.
Feb 28, 2011 | Toshiba Satellite L305D-S5874 Laptop
Ok so I'm fixing this Gateway M-6843 for a friend... When I turn it on it will try to boot but then it goes to a bios looking screen and says Windows Error Recovery at the top and it gives the options of...
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
Aug 21, 2010 | Gateway M-6843 Notebook
Cant get past microsoft windows loading bar
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 26, 2010 | Toshiba Satellite L355D-S7809 Notebook
My Acer Aspire won't boot up past the Window's Loading bar
Log in to safe mode by pressing F8 during startup, if you see windows loading you have missed your window to push the F8 key. When the options menu comes up choose safe mode.
While in safe mode if it loads, click Start > Computer (My Computer) > right click on your ‘C’ drive and click properties > click the ‘tools’ tab > click the ‘Check Now’ button under ‘Error-checking’ > make sure the options ‘Automatically fix…’; and ‘Scan for and attempt recovery of bad sectors’ is checked. A dialogue box will come up stating “windows cannot check the disk”, just click the ‘Schedule disk check’ button and restart your computer. When the computer starts up a check disk will start, let it run. you might want to go do something as the check disk may take up to and sometimes longer than an hour.
Let me know if that helped, and please rate me after, thank you.
Jun 26, 2009 | Acer Computers & Internet
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Acer Aspire 3100-1405
shut down the laptop. power it up, hit F8 when you see the horizontal scroll bar, select save mode and wait for it to load. once it is completed. right click on c:, click on porperties. check the scandisk under the tools tab. restart teh computer.
Nov 02, 2008 | Microsoft Windows XP Home Edition
Gateway T-1631 Notebook Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
