Question about Toshiba Televison & Video
Dvd tv combo, no play reads
Dvd tv combo, dvd reading ,then stats,no disk or incorrect disk and will not play.
    Brigadier General:
  • 3,917 Answers
Given the low usage of the DVD, I doubt that the optics are bad. I would guess that the optics are dirty though. If you feel confident in taking apart the set, remove the lower box from the TV. The VCR/DVD unit is enclosed in a metal cage. You will need to remove the cage and get to the DVD assembly. Carefully clean the lens of the DVD using a cotton swab and alcohol. Re-assemble the unit and try to play a DVD. Since the message is "incorrect disc", the disc is being recognized and read partially. That also indicates correct functioning of the optical assembly. Some data is being read incorrectly however.
Thanks for contacting Fixya
Posted on Jun 24, 2009
Cannot read dvds. Display says incorrect disk
If the dvd player is doing this on all disks then there is something wrong with the laser assembly. Cost to repair for what it is, is prohibitive. If tv has audio video input, connect external player to that for viewing disks OR buy another combo.
Aug 31, 2015 | Toshiba MD13N3 13 in. TV/DVD Combo
Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
electech
Oct 26, 2008 | Sansui VRDVD4005 DVD Player/VCR
19 lcd tv dvd combo
Check it with other discs, known good to you. If they also do displays like this, the laser pickup unit to your combo is faulty.
Jun 09, 2013 | Sharp Televison & Video
I have an Orien FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
My DVD player keeps saying "incorrect disc" when I
cd cleaner may help. lazers find it tough to read discs with dust on it.
Dec 30, 2010 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Dvd won't play
The following suggestion may or may not fix your DVD reader.
You can put a CD/DVD cleaner disk to put into your TV to clean the laser’s eye. The best cleaner disks have the “whisker” that protrudes from the disk and have a fluid you put on the whiskers to aid in the cleaning. Read the cleaner’s directions before using.
You will want to put this disk in your TV at least at three different times to maximize the cleaning.
After you have completed the cleaning, unplug the TV for about 3 minutes. Plug the TV back in and try a non scratched DVD in your TV to see if the cleaning has fixed your problem.
If the TV takes a long time to read the disks and or the TV is not able to read the disks, then the DVD assembly has failed. You could purchase a replacement DVD assembly and install it yourself if you think you are up to it. You just have to remove the stand, the back of the unit, and the old DVD assembly.
I hope this information has helped you.
Good Luck.
May 28, 2010 | Haier HLC26R1 26 in HDTVReady TVDVD Combo
DVD Displays "Incorrect Disc"
Movies and CD's that I've played before in the Sharp now read " Incorrect Disc" . Is this fixableby me or do I have to take it in for service? Thanks.
Mar 31, 2009 | Sharp LC-20DV20U 20 in. LCD HDTV/DVD Combo
Dvd player error
PS has no effect.. Most likely the laser is going bad in the DVD.. See if it will play a music CD* If it will play a music CD but not the DVD it is the Laser. Most of the Laser asm are made in china and don't last long.
Apr 05, 2008 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
I keep getting Incorrect Disk
try to get it set to multi region coding should then play any disc
Mar 05, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
Televison & Video Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
