I have switched the scanner lock to unlock, but it seems to be broken. The display continues to display "scanner locked". If a service manual is available maybe there is a repair or a "bypass" that can be performed.
Thanks
Comments:
Jun 24, 2009
- Thanks, I agree. Are there any tricks to open the printer?
If the lock mechanism is broken as you say it might be, then it will have to be disassembled to be removed. Unplug it, there is high voltage present to run the scan lamp. Be very careful and deliberate while disassembling, you will have to put it back together, or get someone experienced to do it.
Comments:
Jun 25, 2009
- Finding screws under cover and doors or near the bottom are easy, the tough part is popping apart the pieces that interlock with each other. If the latch your looking for is on the back side, then just try to get the back panel off. Even if you can only get it open enough to insert a screwdriver and "break" the latch back out of the way, you will have succeeded. The latch was only needed for shipping.
Try to scan. Error message. The system cannot find the file specified. Software has been downloaded...
(More)
Try to scan. Error message. The system cannot find the file specified. Software has been downloaded from net and installed.?
The individual sheet feeder jams when I try to feed an envelope. It draws the envelope in part way,...
(More)
The individual sheet feeder jams when I try to feed an envelope. It draws the envelope in part way, and then jams when it rolls through without printing.
My scanned documents produces condensed text with three exact images side by side on the single page...
(More)
My scanned documents produces condensed text with three exact images side by side on the single page output
