Acer Aspire One  PC Notebook Logo
Posted on Jun 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blowing cold air but making a bubbling sound
It seems to be cooling properly but is bubbling and water is sitting at the vents blowing the cold air
Anonymous
Level 3:
  • Acer Master 32,281 Answers
  • Posted on Jun 24, 2009
Anonymous
Acer Master
Level 3:
Answers
32281
Questions
Helped
7913331
Points
102259
If there is water in your laptop then most likely it is dead.
My GE Portable AC (Model: ape07ahm1) blows cold air and then after about 15 minutes seems to blow warm air. If I turn it off, let it sit, and start it up, it blows cold again.
First make sure all a/c vents are clear from obstructions like curtains,etc. Also check exterior vents/hose of any debri. If all venting is clear, does the room eventually cool down? If not than component diagnosis may be necessary.
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
1helpful
No heat coming from the vents.
If it is a manual system--sounds like coolant low ie: air bubble in system. If it is ATC system, Check Codes, if no failure codes, coolant may be low--air bubble in system--most Durango's have air bleeders in system.
1helpful
Heater not blowing hot air
Hi Chris, sounds like your thermostat may be worn and not closing all the way which would cause your engine to run cool at times. If you have a temp gage it should tell you if the engine is actually warming up or not. If not I would replace the thermostat.
3answers
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
2006 Nissan Quest - Overheats when sitting idle, A/C won't blow cold when sitting idle, A/C knob will only blow from the face vents when on Max A/C and changes blowing direction on any other setting,...
All seperate things, usually. I'll address these in the order they appear in your note....
It is normal for the A/C air to warm up a bit when sitting, less airflow thru the condensor. However, if the cooling fan(s) are not working properly both the A/C air and engine temp will rise higher than usual.
All A/C's only blow from the dash vents when on MAX.
Drivers window switch could be bad, or the safety sensor is faulty. It sense's upwards pressure, and if to great it will reverse the window. I believe the thought here is to prevent a child from choking.
The tire sensor. If you are refering to the air pressure sensor, it could just be bad, missing, or dead battery.
4helpful
2answers
My 2003 Jeep Liberty heater is blowing cold air when idling. Warms up when you hit the accelerator. I also hear a water rolling sound upon take off after idling. Water pump? Heater Core?
Water level perhaps. When you hit the accelerator the water volume increases. Check your water level and make sure that your thermostat is opening and closing properly. Water level I'm thinking
The car air conditioner is not blowing cold air even after filling the refrigerant; The fan seems to be working fine but no cool air coming out. There is slight cold air coming out from the left vents...
Check you water damp outlet is not blocked. This causes build up of water inside the cabin after a while. Owner manual should help you indicate, otherwise,under the car the outlet should be seen and if no water dispenses when aircon is on, it’s definitely clogged
5helpful
2answers
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Aug 16, 2009 • Home
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
