Question about Jenn-Air JCD2389G Side by Side Refrigerator
My refrigerator is't cooling & my freezer is
My refrigerator is't cooling & my frezer is very cold with ice frozen every where
  • 3 Answers
Pull down plastic panel inside which covers the temp adjustment. In center there is small panel and under neath is computer chip board R&R board. This should fix your problem but be sure to turn ref off and defrost the chiller tubed on freezer side before starting back up
Denny
Posted on Jun 24, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
6 year old LG French Door bottom frezer now has ice builup on the floor of the bottom freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | LG Refrigerators
Fridge/frezer not cold,only at the bottom,act like fan that blows across coils is not working,how do I fix
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
Refrigerator.
If you have determined that the evaporator fan in back of the freezer compartment is running, then you might have a stuck or broken air diffuser. The diffuser acts like a damper to divert air into the refrigerator compartment. Sometimes they jam or break due to frost buildup.
Jul 23, 2008 | Kenmore 53642 / 53644 Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
209 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
