Question about Kenmore 57029 Side by Side Refrigerator
The divider between the freezer and refrig is very hot to touch.
On our Kenmore Elite side by side the center divider is hot to touch.
  • 3 Answers
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Posted on Jun 24, 2009
Is not making ice and is very warm from middle to top on both sides of my side by side kenmore 106.56932600
Greetings,
is there any ice frozen on back wall of freezer panel..if not, check to see if all the fans are operating..does the divider between the refrig and freezer doors seem real hot? if so, look for a stopped condenser fan motor....now, does the compressor run? sometimes you hear the condensor fan running and think the compressor is running...these things will click every fives minutes if not running..So, listen carefully, touch the compressor..is it hot? is it hot and clicking? if clicking, UNPLUG and remove the relay off compressor..shake it and if bad..it will rattle. Replace the relay if bad. The compressor could be bad and be clicking as well..anyway, let me know if it isn't it
Bruce Denton
Jan 24, 2011 | Refrigerators
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Dec 17, 2007 | Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
323 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
