Question about Fedders HF1012 Ductless Split Heat Pump Air Conditioner
My Fedders ductless split a.c. blows hot air with an E5 error msg
I have the 12,000 btu model. It starts blowing hot after about 20 minutes, when it shows the E5 message it 'locks up' and I have to turn it off at the breaker
One ac repairman, inexperienced with 'splits', said 'the lines are backwards - the hot is cold and vice versa'.He is 75% sure it's my capacitor and has offered to replace it - says it's a cheap, appr. $15 part
Another repairman, in a phone conversation, said there should be an error message listing on the wiring diagram inside one of the covers. Found the diagram but no error listing
  • 1 more comment
  • ejw5 Jun 24, 2009
    Freeon is ok. the 'capacitor' guy said my capacitor doesn't look burnt out ( according to him, they usually 'bulge' or show some leakage, etc) but it's still his 1st choice
    Do you suggest I let him try it?
  • ejw5 Jun 24, 2009
    I'd like someone to access the necessary info to tell me what the 'E5' error message means
  • ejw5 Jun 24, 2009
    Still need an ac expert who can access the info on this error code - others need not reply
  • 10,515 Answers
E5 - e5 is comp overload code
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved. Also try, after cleaning the filter, if I remember correct, unplug, wait for a minute, then hold down the power button and plug it back in, it should beep, and thats it.
Then, if you still need assistance:
1. Please contact your installer for warranty service.
2. If your installer is unable to assist in repair or if you need other assistance, contact CareCo for the name of an authorized servicer.
You may contact CareCo by email:
customerservice@fedders.com
by calling the following toll-free number:
1-217-347-6562
or you may write:
CareCo, Service Department
415 W. Wabash Ave., P.O. Box 200
Effingham, IL 62401
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 24, 2009
  • 250 Answers
Short of gas and tripping on auto-resetting low pressure control
Busted reversing valve (though compressor would run constantly)
Broken thermostat
Compressor drawing excessive amps and tripping auto-resetting overload
Condensor fan failed causing unit to trip on auto-resetting high pressure control
try cleaning the condensor while the units off with a brush + vaccum cleaner. Or, compressed air/co2 if you have it
Condenser Fan Motor Running ??
Is the condenser (Outdoor Coil) restricted in any way ?
Blocked condenser might be.
-ray
  • 11,896 Answers
It is possible that a capacitor has burnt out. It may or may not send an error code. It is also possible that the freon levels are low.
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Fedders Air conditioner
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
Cond fan motor runs for about 10 sec then cut off
sounds like it is getting hot need get a can of conpressed air and blow it out.
Jul 30, 2014 | Goodman Manufacturing Goodman MSG18HWN1W...
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
Purchased a fedders a/c 18000 unit still under warranty. called the 800# they said company had filed bankruptcy and were not responsible for repairs. 350$ mistake. Fan runs too slow for unit to kick in....
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Jun 08, 2010 | Fedders 12,000/10,200 BTU Heat/Cool Room...
Heating & Cooling Logo
818 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
