Question about Hunter Vaulted Ceiling Mount - Antique Brass Fan
Two fans, remotes work with one, not the other
We have two Hunter fans, one in the kitchen, one in the living room. The two remotes both control the kitchen fan, but neither control the living room fan. The living room fan light will "randomly" go on and off as will the fan, at all three speeds. My guess is it is responding to a neighbors signal? Help, please!
  • 26 Answers
Re: Two fans, remotes work with one, not the other
Posted on Jan 23, 2009
0 characters
3 Points
Hunter ceiling fan model 23530-300
the roll was rusted maybe .you can take apart it for checking .
ceiling light
May 01, 2012 | Hunter Ceiling Fan Remote Receiver...
We have just bought a home that 3 of the living room/dining room fans are on 1 remote and that remote has quit. We've put in a new battery but it still doesn't work. Can they just go bad ??? Where...
Yes, they can. Another possibility, however, is the jumper settings could have been accidently changed when the battery was changed. Inside the remote is usally four little switches in a row, each can be on or off (zero or one). These need to be set to the same values as the receivers in the fans.
Sep 18, 2011 | Hunter Ceiling Fan Remote Transmitter...
We have Hunter fans through out our home. The one in the family room has a remote control, can the bedroom one be converted to remote control?
yes they can they sell them at all home depot stores just need to take them apart to put it in good luck
Jul 29, 2011 | Hunter Ceiling Fan - 2053
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan and lights comes on automatically
· If you installed more than one remote-controlled ceiling fan, set the DIP switches on both receivers and the control of one fan to an identical alternate sequence (such as "all up" rather than "all down"). Otherwise, when you turn off the ceiling fan in one room, it will turn off the fan in the adjoining room. You can also go to the internet and enter in the GOOGLE search box enter homepage. You should find all the help you need there.
If you found any of this information helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Hunter Ceiling Fan Light Remote Control
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan stopped working after power spike blew the breaker. I reset the breaker and all else in the room came on but not fan. Does it have an internal reset?
If you own a Hunter Original, there is no reset button, but MANY people that have a remote control added (includng me) have , once power has been restored, found that the chain was pulled by someone and it got into the off position, rather than the slow, medium or high setting. With the circuit hot, pull the chain one more time and try to turn on your fan with the remote again.
Hope this helps.
Jun 20, 2008 | Hunter 23852 Classic Original Ceiling Fan
Fans Logo
147 people viewed this question
Top Hunter Fans Experts
Barrett Palumbo
Barrett Palumbo
Mike Butler
Mike Butler
Paul Bade
Are you a Hunter Fan Expert? Answer questions, earn points and help others
