Question about Microwave Ovens
Sweda rapid air oven manual. model 707 - Microwave Ovens
Hugin sweda 1800
aLOT OF OLD MICRO WAVES ARE LEFT IN TO CIVIC AMENITY SITES / RECYCLING CENTRES YOU SHOULD GET A PLATE THERE
Aug 08, 2013 | Microwave Ovens
Door Open light flashes and relay clicks rapidly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, please post a new help request with the full model number from the tag in or on the unit.
Apr 29, 2013 | Whirlpool WMH1163XVS Microwave Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
Hi i need to get my microwave out of demo mode
Hello a1.
Push the start button three times rapidly. The button sequence differs by manufacturer and model number, and since no model number was provided I'll just take this shot in the dark.
Let me know.
fil
Mar 03, 2011 | Panasonic Microwave Ovens
I am looking for an instruction manual for the Kenwood Rapid bake, Bread Maker Where can I find one?
With the Kenwood name, I'm fairly sure Sears PartsDirect will have your model number listed and once on the page for it, you will find the manual listed. The only one I ever purchased was $7 US. Since it is copyrighted, it may not be available as a free download.
Sears PartsDirect
Sep 14, 2010 | Microwave Ovens
Model 26961 rated 13 amps. about how many watts would that equal?
the unit has a rating usually on the inside label ior the door somewhere...
you know the voltage allready... 120... multiply the 13 amps x the voltage... and presto 1560...
you can multiply that by .707 and get the RMS value... 1102
so I consider the microwave to be a 1000Watt unit... pretty easy... bu8t you wonder where did I get the numbers... like .707...
It's to compensate the peak to thr RMS... root mean square... lets just call it "Average"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | Sharp Model: KB6025MK Microwave Oven
Setting the time on a jennair model 166b microwave oven---mfg date november 1991. this thing works like a champ but we have no owners manual---
Jenn-Air's literature site is here. If you enter the full model number from the oven they might have the manual. There's also a link to their customer service department in case you need to try digging deeper. Good luck!
Mar 06, 2010 | Microwave Ovens
I misplaced the book explaining how to use my convection-microwave. It is model JMV8166BAS. The microwave part is fine but I need directions on how to use the convection oven.
Go to Managemyhome.com and enter your model number under the "Manuals" link. Both, the installation manual and operator's manual are available in .pdf (Adobe) format. You can download a copy or print them out for FREE. I hope this helps you.
Sep 08, 2009 | Jenn-Air JMV8166BAS Microwave Oven
Microwave Ovens Logo
587 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
