Question about Frigidaire Dryers
Replaced the felt around the drum and also a new bushing. Door switch reconnected. Dryer won't turn on. What is wrong?
  • 351 Answers
Hmmm you did not short anything or the breaker is not tripped is it?
Posted on Jun 24, 2009
My belt broke as I was rotating the drum with the dryer off to clean the inside of the drum. the drum does not turn freely nor did it prior to the belt breaking. Could there be something else wrong beside...
There are drum felts / seals in the front and back of the drum. If either of them are overly worn the drum will drag. Also if an article of clothing got wedged in either of the seals it will act as a brake.
Before you head off for a belt I would gain access to the drum and check the drum seals and the rollers underneath the drum. If the rollers are sticking that too will make the drum hard to turn. When the drum rollers stick they usually end up with flat spots on them and must be replaced.
Thanks for using FixYa.
Kelly
p.s. dont forget to reconnect the door switch if you took off the front panel.
Mar 05, 2010 | Whirlpool LEQ8000JQ Electric Dryer
The belt broke drum won't turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Dryer will not start
WHEN REMOVING THE FRONT PANEL TO REPLACE THE SEALS DID YOU PLUG THE WIRES TO THE DOOR SWITCH BACK IN? THERE IS A 2ND Q.D. PLUG MAKE SURE THAT IS TIGHT. WIRES TO START SWITCH,DID 1 PULL OFF? HOPE THIS HELPS, PLEASE RATE MY ANSWER, PLEASE FEEL FREE TO CONTACT ME @ HUB APPLIANCE@COMCAST.NET
Jun 24, 2009 | Frigidaire FDE336RE Dryer
Dryer heat but what turn
Mar 28, 2009 | AEG T57800 Electric Dryer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
How to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Aug 29, 2008 | Dryers
Maytag atlantis
UNPLUG DRYER, 220v is not fun
You get in the back of the dryer, from the front.
maytag dryers have two screws in the curve of the bottom of the front panel. (Note:screws may be torx-secure screws, cut a slot in them and use a flat screwdriver or pick up a torx-secure #20 bit at a tool shop, star shape with a pin in it)
remove the screws and the front panel can be swung up from the bottom and unhooked.
unplug door switch wires
reach under drum, for belt tensioner, pull belt off tensioner. and motor pulley
lift drum up and slide out forward
under drum are 2 rubber tired rollers, check for free motion, replace both if either is seized
the drum has felt bushes on it
examine felts for wear, replace if worn.
ensure all felt and adhesive is scraped from drum before fitting new felts, if there is any left, it bumps/thumps and knocks every rotation (best adhesive is Hi temperature red silicone)
use 2-4 pairs locking pliers(visegrips) to install felt
  • put adhesive on drum edge
  • clip felt in place at one point with visegrip
  • pull felt around drum, clipping in place as you go
  • let sit in clamps till adhsive sets
reassemble drum in reverse order
38d7d07.jpg while you got it apart is a good time to clear any lint from exhaust vents and squirrel cage fan,
felts last cost $30/pair rollers $9/pair
takes 45 minutes now to change felts, I do rollers while the adhesive sets, had a lot of practice, replace the belt, cost is minimal, it has been *****ed pulling the drum against the worn felts or rollers, and will break soon, dont want to open up again
Aug 29, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Hot point dryer
the drum has dropped
the drum is suspended on felt pads to seal the drum edges, nylon guides at the front, and rubber tyred thrust rollers to withstand the torque of the motor and belt at the rear.
the usual cause is the rollers have failed, common fault, easy fix, cheap too
good rollers look like this
1ac2db2.jpg worn rollers like this
try not to run the dryer till the rollers are replaced, the extra strain will break the belt,
  • raise case lid
  2. pull tensioner fully agains spring
  3. remove belt from motor pulley
  4. lift drum and withdraw fully forwards
  5. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear
reassemble.
  1. loop belt loosely around drum at wear marks from prior installation
  2. reinsert drum onto rollers bearings slides felts as installed.
  3. loop belt around motor pulley
  4. pull tensioner pulley against spring to end of its travel
  5. loop belt around tensioner pulley
  6. relax tensioner pulley to tighten belt
  7. rotate drum by hand to ensure belt is aligned
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • raise case lid
Notes
May 07, 2008 | Roper REX4634KQ Electric Dryer
Frigidaire dryer gets clothes caught in between the drum, and body of dryer
Just did this today! The brown marks are the felt that is around the part that suspends the drum. It has probably been making a rubbing noise for awhile? The mechanism that supports the drum and allows it is spin is called a bushing This is no longer balancing the drum properly so it is rubbing against the felt and wearing the felt down. The brown marks are burnt felt rubbing off onto the clothes. Get a new bushing assembly and either a top and or bottom felt replacement kit. Replace all worn felt! The top felt has either two or three plastic gliders on it as well. It has been an all afternoon job for me. A second pair of hands is also helpful so long as you are not married to them! Good luck...(I paid $90.00 for a top felt, bottom felt, and a whole brand new bushing unit.)
Feb 18, 2007 | Frigidaire FER231A Electric Dryer
Dryers Logo
42 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
