Cars & Trucks Logo
M
Melanie Shull Posted on May 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'M NOT GETTING FUEL TO THE INJECTORS ON A 85 CROWN VIC . THE FUEL PUMP AND THE RELAY HAVE BENN REPLACED WHATS THE NEXT STEP/
WHY IS THERE NO FUEL GETTING TO THE INJECTORS AFTER REPLACING THE FUEL PUMP AND THE FUEL PUMP RELAY?
Timllfixit
Level 3:
  • Ford Master 2,210 Answers
  • Posted on Jun 05, 2014
Timllfixit
Ford Master
Level 3:
Answers
2210
Questions
0
Helped
484732
Points
5787
You will only get fuel at the injectors when cranking, the pump wont run(Usually) with just the key on. This is to prevent the pump running in a crash and feeding the engine.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 22, 2008
SOURCE: 1996 Crown Vic, Valve noise under heavy acceleration
No use what's in there, but have the engine de-carboned by a Ford dealer, or remove the octane adjust shorting bar located near the ignition module (retards timing 2 degrees), this will in most cases cure the issue unless there is allot of carbon in the cylinders. There are also methods of ing this de-carbon procedure at home, check on the internet for tips.
PLEASE RATE THIS SOLUTION
fordexpert
  • 5692 Answers
  • Posted on May 06, 2009
SOURCE: Wiper motor replacement for a 99 crown vic
I replaced the same part on a 1994 Crown Vic. There are a few bolts which go through rubber mounts on the firewall and that is how the wiper motor fits against the firewall. There is a clip on the wiper drive that must be pressed and slid off the wiper shaft. The hardest part was getting clearence between the engine and wiper motor. If I remember there was a way to turn the wiper case to clear the engine. I have asked myself why this was engineered like this? There is nothing important in the way that 3/4" of clearance could have been given for removal.
Anonymous
  • 548 Answers
  • Posted on Sep 05, 2009
SOURCE: can i replace a fuel pump on a 1998 crown vic
no, if you think it is too difficult it isnt, just get a manual from the library or an autoparts store , and seriouslt make sure the tanks is low or empty and keep clear from sparks !!!
Testimonial: "thank you"
Anonymous
  • Posted on Apr 14, 2010
SOURCE: Location of fuel pump relay on a 2001 Ford Crown Vic
where is the fuel pump relay on a 2001 crown vic p71
Anonymous
  • Posted on Nov 14, 2011
SOURCE: where is fuelpump on 2003 crown vic police intercepter
can you replace a fuel pump from a 2000 Crown Victoria with out removing the gas tank
1helpful
2answers
My 05 Crown Vic LX is misfiring Cylinder 1 2 and 3.
Your next step would be to check for injector pulse (signal at injector) and are the injectors working. Is the miss while driving, at idle, under load, or decell? What codes are u getting?
3answers
Crown vic 2005 no start replaced fuel pump
check your crankshaft position sensor. fuel+spark+compression+timing=ignition.
Fuel pump relay location
Yes In the trunk of some of the Crown Vics there is a switch next to the air ride control. It is called an Inertia switch and has a reset button. If you do not find this switch in the trunk, you will find it behind one of the kick panels above the front seat floorboard. It will sometimes activate by mistake with an impact.
The fuel pump relay should be in a Relay trio that is piggy-back to the Powerbox under the hood on the driver's side. There are plastic clips on one end which when pressed will allow the Relay trio to slide out of the case and towards the engine.
2answers
1999 ford crown vic won't start. changed fuel
Maybe your problem is with the one or many injectors, if just one is bad, you will have problems. Get yourself a multimeter and set it to read in ohms and find what spec the injectors should be at. If out of spec, then you need to replace that one injector(s).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cesar_16d20d38798d492f
84 crown vic wont start
IF THE PROBLEM IS NOT THE FUEL PUMP, FUEL RELAY, FUEL PRESSURE, AND OR FUSE WAT ELSE COULD B THE PROBLEM
1986 crown vic 5.0 EFI will not start. Has working fuel pump and will run with starting fluid but will not start. What is the problem?
there is definately a fuel problem, not getting to engine. check fuel rail for fuel with key in the on position, then check power for fuel injectors, (fuses)
1992 ford crown vic working fine, next day no power to fuel pump or cut off switch
  1. Hi Domino, The fuel shut off is powered by the fuel pump relay (which is in the engine compartment fuse block) the fuel pump relay is powered by the EEC power relay(PCM relay) you will have to check for distribution and voltage. I hope this helps!
3helpful
2answers
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
