Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
How do I take off handle
How do I take off handle I need to tighten up and clean. and I don't have the paperwork is there a screw or allen set screw in the hole on the handle
  • 439 Answers
Yes, it will be a small allen key that needs to be loosened before you can remove the handle.
Posted on Jun 24, 2009
    New Friend:
Here's a schematic to remove or tighten your faucet: http://www.blancoamerica.com/inter/kt/HeilerPPMKatalog/hlr-system/USA/Faucets/BLANCOTORINO1.8/Spec%20Page/441410.pdf Tighten #3 - the lock nut.
Posted on Jan 24, 2013
The handle to switch between the overhead showerhead and the handheld wand won't turn.
Look to a small hole on the adjustment handle there should be a small Allen screw. Loosen the Allen screw set the handle to the desired position then tighten the Allen screw.
Jan 29, 2016 | Grohe Aquatower 3000 Shower Tower...
Loose handle
There is a long vertical handle held to the door by two short horizontal pieces. Run your finder along the under side of the two short pieces and feel for a very small indentation under each one. Each one is a set screw with an Allen head. Insert a small Allen wrench (English not Metric -- I don't know the size, but it is probably the next to the smallest in the set) into each one and back them out (counterclockwise looking up at the screw). The big vertical handle should come off when you back the Allen screws out far enough Now look into the short pieces sticking out from the door. Inside each one is a Philips screw holding the piece to the door. Tighten those screws with a small Philips screw driver making sure that the indents on the front of pieces will align with the vertical bar when you put it back on. When the Philips screws are tight, put the vertical bar back on and tighten the Allen screws. If you have some Loc-Tite, you might use that as well.
Mar 11, 2013 | Marvel 6BAR-BD Beverage Cooler
How to tighten shower door handles
On my glass shower door handles, one inside and one outside there are button like screws hold the shower handles on. If you look closely you will see a small hole in the edge of the button. This hole is used to turn the button screw. This is not an Allen set screw, but rather how you turn the button screw. Insert a small Allen wrench into the side hole and rotate the button screw (not the wrench which acts as a tightening bar) clockwise to tighten or counterclockwise to loosen.
Feb 11, 2012 | Home
The handle on the front of frig is loose....how do I tigthen.
Hi.
The handles are retained by tiny screws. You will need an allen key to tighten the screws. If the handle is damaged you will need to replace the part. If you need to replace the handle buy the single handle rather than the kit. The kit will be more expensive.
Please refer to video and diagram below. Click on the diagram to enlarge the picture:
Here replacement parts for this model.
Regards.
Ginko
Aug 19, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I have a kitchenaid KBLS19KTSS 01 bottom freezer, and the freezer handle has come off on one side. do I need to disassemble the door to reattach it? Or, do the small screws on the bottom of the handle...
It looks like your handle is the style that slips over a screw that is threaded into the face of the door...
According to your owner's manual you most likely just tighten the small allen head screws to secure it. It lists the screw size as 3/32. You should have been left the allen head with your paperwork when you bought it.
Jun 12, 2010 | KitchenAid Refrigerators
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerator door handle is loose
If allen screws are there then that is what holds handle in place. There are screws that the handle fits over, so remove handle and tighten as needed. Allen screws are very tiny.
Nov 27, 2008 | LG Refrigerators
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
1,153 people viewed this question
Top Blanco Plumbing Experts
Marvin
Marvin
Andrew Bugbee
Joseph Hoffmann
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
