Question about Maytag SDE5401AYW Electric Dryer
My dryer starts the flame stays on for 10 seconds and shuts off
Then after 10 seconds starts again what should i do to solve the problen
  • 351 Answers
Change the gas coils and know how to put them on free at whirlpoolpartssurplus.com....
Posted on Jun 24, 2009
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Dec 03, 2009 | Dryers
Flame does not stay lit
check the vent hose first...sounds like it is shutting off from the sensor that watches for that. It might also be the coils on the gas valve are going out.
Oct 25, 2009 | Kenmore Dryers
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Maytag SDE5401AYW Electric Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
