Question about Radio Communications
Radio works great until the engines are started then people cannot understand me because of all the buzz on my transmissions
  • 67 Answers
Ignition noise is getting into your radio, most-likely thru the power source of the radio.
Where are your radio power leads connected into the boat's electrical system ?
Posted on Jul 28, 2009
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have an audi 100 cs quattro. My battery is good but my engine won't turn over. Could it be my starter?
How do you know your battery is good? A common mistake is to assume that if the lights, radio, etc, work that the battery must be good. A lot more energy is required to start the engine than is required for the accessories. If your battery isn't in great shape it won't turn the engine over.
Assuming you've checked that. Can you describe what happens when you try to start the car? Is there ANY noise? Clicking sound maybe? Could be the starter if you hear a buzzing noise (or no noise, assuming you do have a good battery).
Aug 31, 2013 | 1993 Audi 100
Blower, wipers, radio and power windows not on when car is started
You have a IPM (integrated power module) but this is in the engine fuse junction box,It is obvious you have a bad connection,For the radio,wiper and window, it needs a ground, Has someone replace the transmission?look along the transmission see if all the ground connection are there,You are not dealing with a B+ problem but a ground issue
Aug 04, 2012 | 2002 Chrysler Town & Country
I have a 2001 Ford Windstar, ran great until one day I was driving on turnpike and all of the sudden we started hearing a knocking noise from the engine. The more we sped up the louder the noise. We...
a loud knocking noise indicates major engine failure
the mechanic has a lack of ability so get quotes from accredited service center who have experience on your make of vehicle
many mechanics do not understand that on many vehicles it is a relative simple matter to remove the engine /transmission assembly as a unit to work on them rather than to work in vehicle
Apr 08, 2017 | 2001 Ford Windstar
I have a Mirage Omni S8 subwoofer that is approximately 2 yrs old. It has been working great until it started buzzing in the on position whether the stereo is on or not.
Disconnect all inputs. If it still buzzes there's probably a broken ground somewhere inside it. Technical know-how necessary to proceed.
Otherwise, the buzz originates externally and leaks in through the cabling.
Jul 07, 2011 | Mirage OMNI S8 Speaker
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
Drives fine 1 block then no gears, no forward or rev., just rolls. shut it off and away we go for another block, then just rolling until shut off again, also a new buzzing sound in engine.
If you want to try and avoid a tranny change. I highly recommend KW TransX transmission additive. Follow instructions on bottle.
If there is a serious transmission problem this will only prolong failure.
Additive works great!
Here is what the can looks like. Can be purchased at Advance Auto or Autozone.
http://www.midwayautosupply.com/pm-11156-201-k-and-w-products-engine-transx-posi-trac-limited-slip-gear-oil-additive-7-fl-oz-402508.aspx
Dec 24, 2009 | 1991 Mazda MPV
Motorola t5720 one buzzes and you can't hear transmission. It transmits to its partner just fine. It just won't receive transmission form its partner, just a loud buzz
Try trading the batteries between the units and see if the problem moves to the other radio. If so, replace the battery pack. If the problem persists, you have a defect radio, which needs replaced.
Best regards.
Nov 01, 2009 | Motorola Talkabout T5720 (7 Channels)...
My car started to sputter and not work well when it rained and now it jumps outta drive to nuetral while going down the highway didn't have problem like this until after i had new radio installed and dog...
First, take out the radio and unplug the plug from the back of radio. Sometimes, the radio is grounded through a wire that goes hot at certain times. It should always be a ground at any key position. Try test-driving the car with the radio out, not just the fuse out, but the whole thing unplugged. See if your problem clears up then. Sorry about the tranny, and the recurring problem. LEt me know how it goes. TT
Feb 03, 2009 | 1994 Toyota Camry
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
