Question about Kodak EasyShare DX6490 Digital Camera
New memory card wont format!!!!!!!!!!!!
Kodak dx6490 put new memory card and know it wont format internal memory is full is the culprit!!
    Genius:
  • 1,234 Answers
Hello Mr.
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    MY CAMERA IS A Z650 KODAK EASYSHARE, MY DAUGHTER LOST MY OLD MEMORY CARD SO I WENT OUT AND BOUGHT A NEW MEMORY CARD BUT MY CAMERA SAYS IT NEEDS FORMATTING AND IT WONT LET ME ALSO IT SAYS INTERNAL MEMORY IS...
    Just as I suggested. The Z650 works with SD cards, not SDHC cards. Most likely your old card was 2GB or smaller and your new card is 4GB or larger. Try using a 2GB SD card.
    You can clear internal memory by deleting the pictures it contains. Download them to your computer first if you want to preserve them. You can get rid of all of them in one shot by using the "Format" command in the Setup menu.
    Apr 27, 2012 | Kodak Cameras
    My Kodak DX 6490 will not read my 2 Gb or less SD Cards. It keeps recording to the camera memory. I will not play videos onto my digital TV. What should I do?
    Hello, Have you tried formatting the memory card with the camera?
    If a card is formatted with another camera or if it is new you should format it with the DX6490.Hope this helps.
    Russ
    Mar 04, 2012 | Kodak EasyShare DX6490 Digital Camera
    I put ib a new SD card but the camera wont take a picture..It keeps saying...Internal memory is full
    You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
    Sep 19, 2011 | Kodak Easyshare C182 12MP Digital Camera
    Purchased new memory card. camera screen said to format card, camera will not format card please isnsert another. new card is kodak 8gb sdhc. it works in a different kodak camera
    The DX6490 works with MMC and SD cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. Some Kodak cameras can use SDHC cards, but the DX6490 is not one of them. You need to go with SD cards, 2GB and smaller.
    Feb 19, 2011 | Kodak EasyShare DX6490 Digital Camera
    I have taken 8 pictures with my camera and we had put in an 8gb memory card, but my camera says internal memory is full. this is a brand new camera, and I am learning about it, but why is the memory...
    Apparently, you used the internal memory before putting in the memory card. Now the camera only wants to use the internal memory. Here's the fix...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert the memory card. If this is a new card, you will need to format it in the camera, too. If there are any pics on it, download them first using a card reader if necessary, because the card will be completely erased.
    Jul 27, 2010 | Kodak EasyShare M530 Digital Camera
    Camera keeps saying internal memory is full, even after putting a
    Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
    Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
    What is the sd card compacity limit for the DX6490. I have a 8 gigbite sd card and it just keeps asking me to format it. After formating it i put it in a card reader and it still has the pictures i put on...
    The DX6490 accepts SD cards, which top out at 2GB. Cards bigger than that are technically SDHC cards. While SDHC cards will fit into SD slots, they will not work. SD cards will work in SDHC devices, though. So, you're limited to 2GB.
    It's a hardware thing, which no amount of firmware updating can change.
    Feb 24, 2010 | Kodak EasyShare DX6490 Digital Camera
    Bought 4gb memory card for dx6490 but it wont format..is there a way to make it work
    The DX6490 is only compatible with SD/MMC up to 1G.
    It is not compatible with SD/SDHC Cards.
    Pls. use the recommended SD card and the problem should be solved.
    Dec 14, 2009 | Kodak EasyShare DX6490 Digital Camera
    MY kodak easyshare c310 wont work
    Take the pictures off the camera first and then format the card IN the camera.
    Jul 31, 2009 | Kodak EasyShare C310 Digital Camera
    Have new memory card (32G) won't format, was told internal memory is problem but can't seem to erase internal memory to format memory card...Help! R
  • Jun 24, 2009 | Kodak EasyShare DX6490 Digital Camera
    Kodak EasyShare DX6490 Digital Camera Logo
    221 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
