Question about Sony KP-65WS500 65" Rear Projection Television
Why does the screen on my sony rear projector tv model kp-65ws500 turn blue
SOURCE:
Soulvisitor
  • 1113 Answers
SOURCE: converge problem on a kp-65ws500 sony rear proyection tv
You have convergence issues
See this link
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html
and this one
Posted on Dec 29, 2007
  • 2920 Answers
SOURCE: Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Posted on Aug 17, 2008
  • 184 Answers
SOURCE: Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Posted on Feb 13, 2009
  • 41 Answers
SOURCE: My Sony Color Rear Video Projector Model # KP-51WS500
I think Jean got this one right. This sounds just like the problem that this site will help you fix.
Posted on Mar 13, 2009
  • 1170 Answers
SOURCE: Sony TV rear proj works but color is blue
Problem : Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Apr 02, 2009
Screen turns blue on my sony KP-51WS500
Common issue on this set--locate the master screen / focus block and lower the BLUE screen control until the blue cast is gone, only a slight adjustment will be needed.
Dec 16, 2012 | Sony KP-65WS500 65" Rear Projection...
I have a sony KP-65WS500 Ztv turns on but screen is blue with lines. I can hear sound but cant get tv on.the red light blinks five times.. Does anyone know what is the problem?
Can you confirm the actual model number of this set? Some had issues with the picture tubes being bad but depending on model number there may be a fairly easy way to adjust around this to correct the issue.
Apr 27, 2012 | Sony KP-65WS500 65" Rear Projection...
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
KP_65WS500 Tube numbers
Here is the part number for the blue tube B 07MVC61, the Red is R 07MVC61, and the Green is G 07MVC21. The number to contact the company that makes the tubes is 1-800-241-5005 Ext 143
Jun 15, 2009 | Sony KP-65WS500 65" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
I am getting 5 blinks
If the whole screen turns a bright blue and shuts down then you may have a bad blue crt. This will need to be replaced plus adjustments/alignments. Get an authorized Sony servicer to do the repair. Good Luck
Jan 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
