Here's how you can defragment your disk:
Windows Vista, 7:
Disk Defragmenter might take from several minutes to a few hours to finish, depending on the size and degree of fragmentation of your hard disk. You can still use your computer during the defragmentation process.
Once Windows is finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
Windows XP:
For more information refer to these links:
http://windows.microsoft.com/en-in/windows/improve-performance-defragmenting-hard-disk#1TC=windows-7
http://support.microsoft.com/kb/314848
GuruAid.com
SOURCE: my computer dell optiplex x 380 sound driver
Hi.
Here the link to dell download page:
Dell - Drivers and Downloads
try and right click and go to properties and remove the tick mark for read only.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: Hi, In my dell optiplex 380
Most cases the harddrive is faulty if with code the PSA+ 2000-0151 code means Hard Drive (d): - Incorrect status: (x) (s) etc...Caution:Remove any and all power sources Including but not limited to: AC Adapter, Battery, or Desktop Power Cord, before you remove or reinstall an item in your computer." So Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
1st ur oem dell key found on ur pc is compatible with both 32x and 64x but u must backup ur os before reinstalling use windows 7 maintenance section to do a full backup
2nd check ur oem version if on the key if pro or home premium then google to find an iso compatible with ur version but 64x after that head to the dell website and download the specific drivers
