My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Most modern coffee pots have a feature in them to keep you from spilling coffee all over the place when you want to take a cup of coffee before they finish brewing. It sounds like you are having some issues with yours.
Basically, the way they work is that there is some sort of gasket (rubber disk) that has a lever/spring mechanism that plugs the way out of the filter basket when there isn't a coffee pot under the filter basket. They are designed so that the lid of the coffee pot pushes up on part of the mechanism and forcing the little gasket open. (You can generally figure it out pretty easily by fiddling with it.) It sounds like you may not be assembling the lid on the pot completely (this model has a lid where the dome sticks up) or may be missing the lid all together. It's also possible that a piece of packing material may be clogging this or the gasket could be stuck shut, maybe with dried coffee.
One sign that the assembly is working properly is there is just a little bit of resistance (not very noticable) when you first start putting to pot in place and it makes a clicking/thunking noise when the pot fully seats.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
I called Select Brands at 913-663-4500 to order the replacement caraffe for this coffee maker. Their email is [email protected] The website is under construction so orders cannot be placed online. I broke my coffee maker yesterday and still have my lid - guess I'd better keep the lid....
Simply fill with COLD water to the number of cups desired. Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor. Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place. Plug in. Turn on if there is a switch. Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
You must have the carafe lid ON. The reason is the lid has a dome on top that pushes up to let the brewed coffee come down. With the pot off look in there with a flashlight....you'll see that the 1 inch dome pushes up on the spring loaded stem.
You MUST have the lid in place or the brewed coffee won't drain into the pot.
as far as i can tell you cant just buy a lid, mabe on ebay instead of buying a whole new pot or call customer care at 1-800-835-3278.
Let them know you just need a replacement see what they say. Heres the item number for it on ebay, only one day left at $16.99 200133333009 , and heres the link
http://cgi.ebay.com/New-Coleman-Stainless-Steel-12-Cup-Coffee-Pot-805D712T_W0QQitemZ200133333009QQihZ010QQcategoryZ87143QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
