Question about Goodman Heating & Cooling
My split type AC won't blow on high fan. Goodman WMC24 1A
Goodman Air Conditioner WMC24-1A access cover
Posted on Jul 27, 2009
YOR HI WAAL A/C WNATED BY DRY SRVICE
Posted on Jun 24, 2009
Cond fan motor runs for about 10 sec then cut off
sounds like it is getting hot need get a can of conpressed air and blow it out.
Jul 30, 2014 | Goodman Manufacturing Goodman MSG18HWN1W...
My goodman split system AC unit is running but the fan won't run even when I switch it to fan on thermostat. Any ideas please?
Did you notice if there was a click at the blower cabinet when you were switching the fan switch back and forth? If it clicks you probably have a bad fan motor. If it doesnt you may a bad thermostat, relay or relay board. Hope this helps good luck
Aug 14, 2013 | Heating & Cooling
Ac will not blow out vents
Hi, each fan or blower have switch to work on high and low blowing air. Check your blower switch first.
Jul 19, 2013 | Nissan Titan Cars & Trucks
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Not cooling good
while the machine is running, partially block the outdoor fan until the high pressure reaches 270 psi, the low pressure should be 70 psi at this time. This should be true within 10 lbs.
Jun 24, 2010 | Goodman CLJ42AR49 Air Conditioner
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
I have a goodman gmnte with a 16 seer ac, just
yes in the air handler the blower will have possibly 4 wires the ones you are needing are red blue and black1 will go to a relay or possibly a circuit board and the other 2 will capped off, black is high speed, blue is medium, red is low, most come from factory on med.
Aug 11, 2009 | Heating & Cooling
Heating & Cooling Logo
192 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
