Question about Her Interactive Nancy Drew: Danger by Design for Windows
DDERR WRONGMODE MESSAGE while playing Nancy Drew
For some reason the screen went black and a text box told me the program was set up or created in DDERR.....WRONGMODE. Unfortunately, I can't be more exact. I'm not sure what it means. How do I fix it so I can keep playing the game?
4 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: Nancy Drew game white wolf -video flashes by so text not readable
it could be that the video card is not powerful enough or that you need to update the version of direct x that you have. Check your version of direct x by going to start, run (on the right hand side) and type in dxdiag and press enter, the first screen that will be displayed will have your version of direct x. If it is not as high as 9c then I suggest that you download direct x 9c from microsofts website or run a search in google for it. Download it and this will update your directx. Secondly when you are in the dxdiag program check under the display tab and make sure that 3d features are enabled. If they are not or you do not have this option (because it is greyed out), then you may need to upgrade your graphics card.
I hope this helps
Posted on Dec 24, 2008
SOURCE: Nancy Drew game wont work.GRrr...
Hi, when i play some of the Nancy drew games the arrow or magnifying glass is very jerky to where I can really paly the game. Any ideas?
Posted on Jan 16, 2010
  • 11 Answers
SOURCE: well i have directx version 9c but my text in
Is there a setting under options to change what you can view regarding text? Some programs have it and some don't.
Posted on Jan 02, 2011
Hi, The game, Nancy Drew: Danger by design, doesn't work in my laptop. Every time I try to play the game, the screen freezes but I can hear the music at the back ground. All the other Nancy drew games...
The first thing you should try, is to update both JAVA and Flash. If it uses those, that is likely the issue.
Here are the links:
http://www.java.com/en/download/inc/windows_upgrade_xpi.jsp
http://get.adobe.com/flashplayer/
Be sure to uncheck the boxes that install toolbars. Also, it wouldn't hurt to make sure that Windows is up to date. Click the Start button, click All Programs, and then click Windows Update.
Jul 11, 2011 | Her Interactive Nancy Drew: Danger by...
Can't install "message in a
I found a possible solution for this problem with another older Nancy Drew Game; I would try this solution and see if it helps with your problems.
The game is too old to run on Vista (assuming that's what you have) but it's easy to fix.
Just do this:
•First, uninstall the game.
•Next, reinstall the game--but don't do AutoPlay. Instead, go into my computer, right-click on the game's icon, and choose "explore".
•You need to then find the "setup" icon, and choose "properties". There's more than one "setup" icon, but only one that allows you to choose "properties".
•After that, go to the compatibility tab, and check the box that says something like "make compatible for"...choose XP, or ME/2000 if you want to play it safe.
•Exit out of the My Computer screen (though in Vista, it's just called Computer). On the start menu, open up your **Documents** window.
•Create a new folder and name in Message in a Haunted Mansion, or something you will, without a doubt, remember.
•Go back to Computer, double click on "setup" and start installing.
•Install as normal, but when you get to the part where you save the game, it's very important that you save it in the documents folder you created. Otherwise, it won't automatically create a folder for itself, and problems occur.
Here is the link to the solution I found:
http://answers.yahoo.com/question/index;_ylt=AkRXosX54.vFNS0wRZSOqLjty6IX;_ylv=3?qid=20091127101804AAIwP95
Jan 01, 2011 | Her Interactive Nancy Drew: Message in a...
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
Picture won't show up for nancy drew message in a haunted mansion
these are the min. specs for the game>
System Requirements:
  • Windows 95, 98, ME, 2000, XP
  • 166 MHz Processor
  • 16 MB RAM
  • 200 MB available hard disk space
  • 16 Bit color graphics video card that's compatible with direct X 6 or higher.
  • 8x CD-ROM drive
  • 16 Bit compatible sound card
  • A pointing device and speakers
Platform: WINDOWS 95/98/ME/XP
Oct 06, 2009 | Computers & Internet
Sep 01, 2009 | Microsoft Age of Mythology: The Titans for...
Im trying to play nancy drew secrets can kill, and its all instulled. however when i click on the shortcut to play the game i get a black screen with a box in the middle that says ''nancy drew is unable to...
if you desperately want to play nancy drews that have that problem, there is a way but this way youl have no sound but the game will still play.
Go into the directory where you installed the game and then o into the game.ini file. it should open in a notepad.
go to sound system is active=1.
change the 1 into a 0. then enjoy. the game may have no sound but its still the game ayyy
nd dont try and change the volume or else the game shut down.
Aug 31, 2009 | Her Interactive Nancy Drew Secrets Can...
I get the following error message trying to load Nancy Drew Danger on Deception Island... Incorrect path to ini file
You create a new folder, name it something like "deception" and save it. Then insert the disk and begin install, when it asks you where you'd like to install it, click browse, and install it in the folder you created previously. It won't work if you just install it in the recomended folder...
Apr 28, 2009 | Computers & Internet
Incorrect path to INI file
install the game and when it gets to the install on C:\nancy drew click browse and choose program files then install there the game will then run but requires the cd to be in the drive
Jan 01, 2009 | Her Interactive Nancy Drew: The Secret of...
Her Interactive Nancy Drew: Danger by Design for Windows Logo
Top Her Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Her Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
