Question about IBM ThinkPad T60 Notebook
It died, how do I remove it - IBM ThinkPad T60 Notebook
  • Gary Luis
    Gary Luis May 11, 2010
    Remove what?
    Problem Solver:
  • 7 Answers
I think by "remove" he means "reformat." Just pop in your Vista disk and follow the instructions please...
Posted on Jun 24, 2009
Battery is dead. Once jumped n the jumper cables are removed it dies again. My vehicle is a 02 Buick lasabre
Once jumped n the jumper cables are removed it dies again. I would think it's not charging , alternator problem maybe .Is the battery light lit on the instrument cluster ?
May 08, 2018 | Cars & Trucks
Fault finding
vacuum lines to tank may be located on wrong pipes
Mar 03, 2014 | Yamaha YZF-R6 Motorcycles
Hi, I have a model 358.791072 weedwacker that dies after about 1 mins of use when I give it gas. I replaced the spark plug,clean the carburetor and the fuel filter.It's still died after short time. How...
The machine is either dying "rich" or dying "lean." A carb adjustment could remedy either scenario. A better fix is to remove and disassemble the carb and install a low cost gasket and diaphragm. If you install that kit, and adjust the carburetor properly, the dying should cease.
Sep 02, 2011 | Garden
I have a makita jn1601 nibbler and I'm trying to change the punch. How do I do this?
Removing or installing the punch and die
Always replace the punch and die as a set.
To remove the punch and die, loosen the lock nut with the wrench.
Remove the die holder from the tool.
Use the hex wrench to loosen the bolts which secure the die. Remove the die
from the die holder.
Use the hex wrench to loosen the screw which secures
the punch.
Pull the punch out of the punch holder.
To install the punch and die, insert the punch into the
punch holder so that the notch in the punch faces toward
the screw.
Tighten the screw to secure the punch.
Install the die on the die holder.
Tighten the bolts to secure the die.
Then install the die holder on the tool so that the punch is
inserted through the hole in the die holder.
Tighten the lock nut to secure the die holder.
After replacing the punch and die, lubricate them with machine oil and run
tool as needed
Here is a link to a manual in case you need it to:
http://www.makita.ca/data/upload/tools/(JN1601)883894-943_75725_owner_English.pdf
Thanks for using FIXYA
Please rate us.
May 25, 2011 | Makita Garden
Dash lights come on..mph gauge went down..radio cut out..loss of power in engine..kills batterie. While running, removed pos. batt. cable and engine died. Altenator problem??
You need to replace the Alternator. The vehicle died because you removed the power supply to all the accessories, if you remove the Negative cable and it dies then you know for sure it is the alternator. that is an old shade tree way to test the alternator.
Apr 05, 2011 | 1996 Isuzu Rodeo
1990 ford tempo starts but will die after about 10 minutes. the power from the battery is drained and we just bought a brand new battery for it.
Try to start again, then when the engine is start, remove the negative or positive battery cable, and if the engine die, the alternator is failed., and if not dying, alternator still good. But for me the way you said, I'm 100% your alternator is died. Need to replace a new one. And if you know how to solder, just remove and replace the brusses( carbon) by soldering. ok
Mar 26, 2010 | 1990 Ford Tempo
I have a 1998 Mercedes E430. The car died... let
check your gas cap it might not be venting the tank properly remove gas can and see if that helps
Jan 07, 2010 | 1998 Mercedes-Benz E-Class
My 1994 buick regal will die with no regularity. when I boost it and remove any of the jumper cables it will die. Mechanic says alternator, battery and starter are good and the crank sensor is bad--what...
Odds are very good if once you remove the jumper cables it dies that it is the alternator. Once running, the car runs directly off the alternator so if it's quitting, it's a sign the alternator isn't puttling out enough amperage.
Dec 13, 2009 | 1994 Buick LeSabre
Motor Speed Question
The RPM rating of the die grinder is the deciding factor in the tool’s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
Aug 27, 2008 | Viking Die Grinders: 1/4" Heavy Duty Die...
IBM ThinkPad T60 Notebook Logo
46 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
