Question about Sony Handycam DCR-TRV140 Digital Camcorder
Sony Handycam Dig 8 doesn't recognize tape when trying to record
I have a Sony Digital Handycam DCR-TRV140 NTSC
In camera mode, it does not recognize the tape when trying to record.
However, in video mode, it will fast forward, play, rewind, etc.
Thanks for your assistance!!!
KT
    Novelist:
  • 107 Answers
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 24, 2009
I had the same problem and the sony tech guy walked me through it. First check that the tape is not in the "locked" position and will allow recording (you can also use new tape). Next, remove the baterry and place the switch on either VCR or Camera mode and wait for 2 to 3 minutes for all of the residual power in the camera to dissipate. Return the switch to the "off" position and reinstall the battery. Now, open the lid of the casette compartment and press the reset button using a pen or pencil tip. The button is small and is about half an inch to the right of the eject button. This worked for me.
If this does not work there may be something internally wrong and SONY will fix it for a flat rate of $171.00 which includes ALL internal parts replaced (left "like new") and shipping back to you. You will have to pay shipping to Sony. It also includes a 90-day warranty and takes less than 12 days turn-around time. Phone number for sony is (800) 488- 7669. Hope this helps you. Good Luck.
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
How to save videos from sony handycam to my home pc
you need to put the camera into playback mode
then go into the menu and go to the setup menu
Then USB streaming and turn it on
That should enable the computer to recognize the camera
May 29, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Nothing happens when I turn on the camera - message C:31:23
This error usually comes when there is some mechanical fault instead of the electronic one. Maybe the gears are jammed. Try it at your own risk:
I found this on another discussion forum. Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. Surprisingly it worked for me..
Apr 01, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
MY COMPUTER DOES NOT DETECT MY SONY DIGITAL HANDYCAM DCR-TRV140 NTSC
Here's the USB driver for your camera:
http://www.helpdrivers.com/ingles/listado/dow.asp?codigo=81834
Click download (middle of page) . Run this driver . After that connect your handycam. Now your pc will recognize your handycam and be ready to use.
Good luck !
Chris (ziraffa)
Dec 26, 2008 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Apr 07, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony Handycam Digital 8 DCR-TRV140/Pinnacle Instant DVD Recorder/Windows Vista Home Premium/Sony Vaio
I have a sony hi 8 video camera recorder. Someone dropped it and now we cant get the tape out to put in another camera. Can I use a USB to get the information off the camera?
Jan 19, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-TRV140 Digital Camcorder Logo
321 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
