Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opens 1 foot, then stops.
I can disengage the door from the trolley and open it all the way. With the door disconnected, the trolley also travels to the fully open position. With the door attached to the trolley, it stops after one foot. I've lubed the chain, trolley and guide rail, and still no go.
    President:
  • 3,197 Answers
It sure sounds like you have a broken door spring. While you are at it remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Might be stripped and unable to take the weight of the door.
Posted on Jun 24, 2009
Garage door opener just hummms
For chaimberlain family openers, the gear inside is shredded. For genies screw drives, replace the trolley. Assuming you have not disengaged the door from the opener by pulling the red cord.
Aug 19, 2014 | Building Materials
Motor hums but does not open garage door
Either the opener trolley is disengaged or you have a broken gear/sprocket assy.
Mar 26, 2014 | Sears LiftMaster Building Materials
We just replaced the "trolley" component of the opener, now when we open the garage door it opens about a foot, then stops like its hung on something... it will go back down. If i help it pass the hun
Check your manual and re-program the up/stop and down/stop position. Also make sure the new trolly is in it's proper position.(in the closed position) Hope this helps
Oct 02, 2012 | Chamberlain 3/4-HP Power Drive Chain Drive...
1/2 horse garage door opener doesn,t open all the way. I need about a foot more lift. The tried a trolley stops before the stop limit..Therre is no interference. I Tried adjusting the up limit to no...
You said you adjusted the up limit already. Is it adjusted as far as possible? Usually the screw will become harder to turn. You mention a new door and spring but is the opener the same? My guess is you have a new opener as well and it is out of sync with the trolley. Try turning the up limit back and see if the trolley will stop shorter. If it does, loosen the chain or belt so that you can remove if from the opener's drive gear. Bring the trolley to your stop limit and put the chain/belt back on the gear. Adjust the chain/gear tension and try door operation again. If it was a sync problem, the door should close closer to your limit. Adjust up and down travel as necessary to fine tune it. This worked for me so good luck.
Sep 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
My i/2 hp crafstman chain drive opener stops about a foot from the floor i got it up and noticed the chain was sagging about a foot below the bar how dow I tighten the chain
The adjustment for the chain is on the trolley. That is the part the chain and the door are connected to. Your chain is sagging entirely too much. Have you done any other work to this opener?
Oct 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door can be opened manually when the trolley has
You can adjust the length of the arm between the trolley and door so that it is in a vertical position when the door is closed. This will prevent your problem.
Oct 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
794 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
