Question about Garden
Cub cadet 2145 (Onan engine)runs the battery down
My cub cadet 2145 (Onan engine)runs the battery down. The amp light stays on. What is my problem?
  • rraubry Jul 17, 2009
    My cub cadet 2145 (Onan engine)runs the battery down. The amp light stays on. I swapped out the voltage regulator, but the amp light still remains on. What else could I try in fixing the problem?
  • Anonymous Mar 16, 2014
    why does my cub cadet snow thrower engine surges when running
    Sniper:
  • 109 Answers
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Posted on Jun 29, 2009
Cub cadet lt1050
Is the red light on before you engage the blade?
There may be a blown diode in the charging circuit.
Battery- If this light illuminates while the engine is
running, it indicates that the battery is in
need of a charge OR that the engine's
charging system is not generating sufficient
amperage. Refer to Battery on page 26 of
this manual for the properbattery charging
procedure or have theengine's charging
system checked by a Cub Cadet dealer.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Aug 27, 2014 | Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Cub Cadet 2145 with 14HP Onan Engine.
sounds like you may have ignition coil or module whichever you prefer (one in the same) may be heating up and shutting down? Check all your grounding connections also
May 28, 2010 | Garden
Cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
529 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
