Question about Dell Computers & Internet
My computer will connect but with limited access. Inspiron 1525. All other computers in the home work but not mine. Does this mean I need a new network adapter? Repairing and diagnosing does nothing
    Problem Solver:
  • 7 Answers
Go to:
http://support.dell.com
Select Enter Your Service Tag Number. This will create a list of all the drivers needed for this PC. Be sure to select the correct Operating System.
Then select the NIC or Network Drivers, Wireless Drivers or Both. Get the most recent version and install them on your PC. If the card is just having connection problems, but works, it could just need updates on the drivers.
Good luck...
Posted on Jun 24, 2009
Limit internet access network
Make sure that the presence of the Internet in the router, restart or
- Switch the device on your computer and open it again
Oct 09, 2013 | Dell Inspiron 1525 Laptop
Have 2 dell inspiron 1525s, can I use the hdd from one in the other without having to reformat the good hdd
Swapping hard drives from one computer do not work because of hardware differences even between same brands and models.
You can install Windows XP on his computer but you need the Windows XP installation CD and you will need to use the product installation code from your computer. It is printed on the Windows label that is attached to the bottom of your laptop.
Mar 21, 2013 | Dell Inspiron 1525 Notebook
How do you change limited internet access to full access
Limited access usually means you have full access to your network through your hotspot, but the hotspot is not connected to the internet or it cannot get a signal.
Sep 25, 2012 | Dell Inspiron 1525 Laptop
Can you please tellme how to unlockmy dell inspiron 1525 laptop.i have tried every possible means till now....plizzzz
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jul 07, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525 and I turn on my wire less switch. What can I do?
Do you mean what happens when you turn it on? you allow your computer to find wireless networks. eg. linksys. netgear. etc. will all be able to connect to your computer. If you dont use wireless connection then it is recomended to keep the switch off to help your computer run faster.
Jun 29, 2011 | Dell Inspiron 1525 Laptop
I need to know y my computter dont get internet
Because your wireless network is lacking ...
There are many reasons for limited coverage with wireless ... aluminised wall paper, multiple walls, electromagnetic fields. With your computer, the antenna is probably minimal.
If you want good, fast coverge, run some Cat 5 wire to the places you require access where there is no wireless. The wire connections will work better too.
Feb 14, 2010 | Dell Inspiron 1525 Notebook
Time of day clock stopped - DELL Inspiron 1525
This is one of the known issues with the Inspiron 1525 computer.The problem is caused by faulty cmos battery. If you computer is in warranty kinldy call Dell to get the same replaced . if the system is out of warranty. You would need to replace the CMOS battery ie below the keyboard.
You can follow the instructions below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/coinbatt.htm#wp1179839
Thanks
Proton
Feb 06, 2010 | Dell Inspiron 1525 Notebook
Inspiron 1525 was working fine yesterday but today wont boot. Says it can't access the hard drive.
Does the hard drive LED flash and the hard drive spin up when you bootup?
If it doesn't then you could have a faulty hard drive or a fault disk controller.
Reseat the hard drive to see if it is a connection problem.
If the problem still persists then to test if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter.
Connect this to a working computer's USB port and if this computer sees it as an external hard drive and you can open the folders and files then the hard drive is OK.
If not then the hard drive is faulty and you need a new hard drive in the Dell and Windows installed etc. to get the Dell operational again.
Jul 14, 2009 | Dell Inspiron 1525 Notebook
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
My WiFi isn't working on my Ispiron 1525?
this is working thanks a lot dear
i solve out my problem
thaks again
take care
and share the knowledge
Feb 01, 2009 | Dell Inspiron 1525 Laptop
Computers & Internet Logo
140 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
