Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Motor willnot start. clicking noise when i try to start it. the battery is good and i jump started it with my car--started great. i have cleaned the posta and cables
    Problem Solver:
  • 11 Answers
The problem is the starter cylinoid . this is going to set you back about 10 to 15 dollars.
or it could be your starter trying to go out, it will crank off your car battery because you are using more amps to crank it..
a car battrey has more cranking amps than a small engine battery..f.y.i.
Posted on Jun 24, 2009
2008 explorer starts with jump, shut off will not restart, clicking noise
clean battery posts and cable ends and make sure to tighten securely when done
Aug 31, 2014 | Ford Explorer Cars & Trucks
Will not start starter makes click-click-click noises, battery fine, starter fine , starter relay fine, battery connections and starter connections are clean and still keep doing click-click-click noises...
We'd need to know more about how you have assessed these components, but something in that chain is still faulty. The symptoms you describe are classic, the sound of the starter solenoid pulling in, and arise almost always from
- a dying battery which cannot hold a full charge, but which can still pull in the starter solenoid, run the radio etc, but not crank the motor
- worn starter solenoid main contacts which cannot close the supply circuit from battery to starter motor
- a dead segment in the starter motor armature which is preventing it from rotating
- a bad ground, usually between motor body and chassis
You have mentioned all these things I know, but that click-click is a first step which still points the same way..
One way to narrow it is to try jump starting your motor from a known good battery or another car with running motor, taking precautions to avoid frying your electronics. If it starts, it is a bad battery you have. If it just clicks, then one of the other causes.
Feb 26, 2014 | 2000 Pontiac Sunfire
My 2006 chevy trailblazer 2wd 6cyl wont start. makes clicking noise, then nothing lights/radio etc work but wont start what is it
You got a jump and it ran fine? It's your battery. The lights and radio are much easier for a battery to handle than spinning a car engine. Again, if all you needed was a jump, you have a bad battery.
Jan 20, 2018 | 2006 Chevrolet Trailblazer
07 buell lightning xb9... stored for a while and now when attempting to start a loud clicking noise... tried to jump started but same clicking noise... new battery???
I have a Buell M2 and a Buell Rirebolt.
When the batteries go, they leave us with clicking solenoids. There is enough power for ignition but not enough for the starter motor, hence the clicking noises.
That is possibly what you are experiencing.
Hope that helps.
Nov 26, 2010 | 2007 Buell Lightning CityX XB9SX
Car wont start until i give it a jump i put new battery and had alternator checked its good. when i try to start it all it does is make clicking noise
Sounds like an intermittent Earth connection. Check all the battery and earth leads where they connect to the Battery, Engine, Starter Motor and Body. If possible disconnect, clean and reconnect.
Aug 20, 2010 | 1997 Chevrolet Lumina
Wont start funny clicking sound when i turn the key ???
Hi!!
The clicking you are hearing, is the sound of a weak battery, Jump start the vehicle and take it to an AutoZone for a Charging System check.
Good Luck!!
Mar 20, 2010 | 2006 Land Rover Range Rover Sport
My gauges work but it wont turn over i dont hear any noise from the starter
Three possibilities I think:
First is weak battery. There may be enough juice to light the gauges but it takes power to turn an engine.
Second, bad solenoid. The solenoid is a relay which closes the high current circuit that delivers the cranking power to the starter motor. If you hear clicking in the engine compartment (not the starter) when you turn the ignition switch on it is probably the solenoid engaging and disengaging. However if the battery is weak it won't turn the starter motor. If the solenoid is clicking look at the battery first. The solenoid could be bad but the clicking indicates it's trying to work and there just may not be enough juice to turn over the engine.
Third possibility is the starter motor itself is dead. You have to answer some questions for yourself. Is this an old,neglected car or one that has been taken care of? I would be looking at battery. Can you jump start it? If yes then weak battery is the likely problem. If the car and battery are relatively new and in good condition you should suspect the charging system, that is, the alternator. Did this happen all of a sudden on a car that was running fine recently or has the car been sitting idle for weeks/months.Eliminate the easy stuff.
Clean battery terminals?
Good battery connections and ground?
Try jump start - if yes then follow up battery/charging system. If no start then try to hear for solenoid clicking. If jump start does nothing -figure the solenoid first. If it sounds like solenoid is kicking in but engine does not turn then the starter is looking a little guilty. Jump starting will answer a lot of questions. If the car is really dead then the car that is jumping may have to be connected and revved up a couple minutes to juice up the dead battery enough to turn the starter over. If it turns over a little during the jump start but just barely then you should figure your battery is bad.
Sep 04, 2009 | 1992 Chevrolet S-10
2000 toyota rav4 wont start
try putting it in neutral and try starting it.it maybe that the neutral safety switch is out on it which means it wont start in park
Jan 22, 2009 | 2000 Toyota RAV4
2004 trailblazer
Hmmmm, from what u say, sounds like everything is ok, but,Bad battery can run lights, radio, but trying to start, will make clicking noise. U jumped it to start, and it did, another sign of bad battery. How are the connections at battery? Tight and clean? No corrosion? Check wire to starter also to make sure it's ok. If all connections are clean and tight, I would recommend removing the battery, take to parts store for free check to see condition of battery (low charge, or if it's shot). If u jump start it, u can also have them check the alternator too (free). U indicate dash gauge @ 14, that should be good. Battery usually has a date 'thingy' on it that u peel off #'s to indicate when battery was purchased, does yours have the 'thingy?'
Jan 12, 2009 | 2004 Chevrolet TrailBlazer
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
411 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
