Question about Samsung HL-P5063W 50" Rear Projection HDTV
Model 5063W - loud noise
Model 5063W - turn TV on and we hear a loud ratchet sound. Picture is pink. Think it might be the fan or the color wheel but how do you really know?
    Problem Solver:
  • 15 Answers
Color Wheel. Have this TV also. When the color is distorted that ratchet sound you are hearing is the wheel starting to rub and on the brink of breaking. Mine shattered to tiny bits. The fan would just get loud and would cause tv to shut off repeatedly. It's a bit annoying but make sure to doublecheck the type of "chassis" that your wheel has. Easy to replace as a DIY project.
Posted on Feb 27, 2013
  • 439 Answers
The picture is pink, that would point more toward the color wheel, and you can see the fan through the vents in the back and you can go from there. It sounds more like the color wheel since you have a picture malfunction.
Posted on Jun 24, 2009
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My tv is a samsung dlp 5063w I change de dlp bulb and now is working good but from the back of the tv is a loud noise
Ok look my friend..
first i need to know what type of sound is it. like a click or a buzz?
and then here are 3 suggestions.
first clean your TV with some latex globs and a can of compress air try to do it really good try that...
second. check that all the cooling fans are working just fine!
last one. its your color wheel and you need to change it.
here is a link were you can find the part and not so expensive prices!
http://www.discount-merchant.com/PANASONIC-Cooling-Fan-Set-Cooling-Fan-Set-p/1002171.htm
http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0
good luck!
Jan 21, 2010 | Samsung DLP HL-P5663W 56" TV
Our TV is making a loud humming noise. We think
It's likely your color wheel rather then your fan. I've replaced quite a few of these and the fans are usually good. Get and estimate - I generally charge $250-350 Total
also google your model # and color wheel to investigate further.
Oct 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
Color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Jul 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Apr 22, 2007 | Samsung DLP HL-P5663W 56" TV
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
266 people viewed this question
Jerry Greenberg
Jerry Greenberg
