Question about Sony KP-46WT510 46" Rear Projection HDTV
Where is the convergence button on a Sony 46?
Help! My Sony 46 just started to have a red outline of everything. Where is the convergence button at?
  • 202 Answers
You will have to use the menu, it should have auto convergence settings. if not the service manual would be needed to get to the service menu.
Posted on Jul 09, 2009
Screen has red outline
One of possible 2 things. You can go into menu and try and adjust the red convergence settings and hopefully that will take care of it. It possible if it wont adjust that one of the convergence ic chips has failed or could be a weak picture tube. Try adjusting the red convergence and hopefully your problem will be solved. Check you owners manual if you have trouble but its not to hard..
Oct 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
There are suddenly red outlines on people and the left side of the screen has a red line going up and down. I have an HD rear projection 46" TV.
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The middle of the picture is fine but the sides of the picture look like they are double with a red outline
The TV has a convergence problem, the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Thanks for choosing FixYA, Big Irish.
Nov 22, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My sony 46 kp46wt510 panel tv has red outline on images
its more likely needing the convergence ICs replaced. You can get the convergence repair kit for your model at the following link which contains both IC the six pico fuses and four of the feed resistors, The kit comes with instructions. Heres the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
