Question about Craftsman Garden
I've had the same 14.5 Craftsman mower for the past 8 years and have had few serious problems, I was mowing and when i went to turn the mower back on after emptying the grass bags the engine wouldn't start, it wouldn't even turn whatsoever.
    Problem Solver:
  • 11 Answers
Sounds like your starter is over heating.
1) make sure that there is adequite air flow to the starter and surrounding engine components from the fly wheel.
*in other words no grass or foreign debris obstructing the engine air flow.
2) make sure the batter terminals are good and tight.
3)make sure the starter cyliniod isnt bad.
*and also the wire's to the cyliniod are good tight.
Posted on Jun 24, 2009
Tip
Safety For Riding Mowers
<span> <ul> <li>Do not give children rides on a riding mower, even with the mower blades not turning.</li> <li>Children may fall off and be badly injured or interfere with safe machine operation.</li> <li>Children who have been given rides in the past may suddenly appear in the mowing area for another ride and be run over or backed over by the machine.</li> <li>Do not mow with a riding mower in reverse unless absolutely necessary.</li> <li>You can be seriously injured or even killed if you use a riding mower on too steep an incline.</li> <li>Using a riding mower on a slope that is too steep, or where you don't have adequate traction can cause you to lose control or roll over.</li> <li>Always consult your operator's manual for safety messages concerning operation on a slope.</li></ul></span>
on Apr 02, 2011 | Garden
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Hi, My YTS 4000 is shutting down after mowing for a short period. I believe it is not getting fuel flow. could you assist with this problem?
no professional, but my father's Murray did the same thing a few years back and it was the Coil going bad. Replaced it and it was fixed. Hope this helps.
Nov 11, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower LT3000 blades won't engage/turn
Well, we wouldn't want to lose your little girl, but goats can be very lovable.
The problem could be it just needs lubricating. I'd first spray WD-40 on every part of that mecanism which moves, top to bottom, even inside the button on top and underneath the deck.
If that doesn't work, get back to me, please.
May 09, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
101 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
