Question about Electronics - Others
Wireless speakers will not work.
I hooked up the wireless speakers and I have never been able to get them to work. what else should I do? I have the wires hooked up to the stereo.
    President:
  • 1,114 Answers
Post the Model #'s of the products involved and I can be a little more specific. Using generic troubleshooting, First: make sure you have the wires for the receiving unit of the wireless speakers hooked up to either "A" Front or "B" Front. thenmake sure your receiver speaker switch for the corresponding location is on. It will light up on the front of the receiver either A, B, or both. Now, turn on the AV receiver and Tune it to a strong radio signal in your area, turn up the volume 1/4 to 1/2 way. Power the wireless units on. Both the speakers and their receiver should have a power button or at least a light to let you know they are getting signal. keep the speakers close and fine tune the wireless receiver with them until the led light on the front of the speakers is solid. You should have good audio at this point.
The other way the wireless receiver is hooked up is with RCA cables to the AV receiver. Without knowing what AV receiver you have, plug the RCA's into an "Output" like "Front Main Pre Out" or "VCR/Tape2 mon" or just plain "Monitor out" Depending on which Output you use will determine the setting on the receiver. If you need further clarification, post your equipment model numbers and I can tell you exactly what to do. Hope this helps
Posted on Jun 24, 2009
Can I hook up other speakers instead of the orginal ones
yes you certainly can. If the speakers fit the jack, then you can use any speakers. You can even use a wireless transmitter and even hook it up to a stereo system.
Aug 12, 2010 | Logitech Z-5300 Computer Speakers
I have a wireless speaker that I hook up to my direct TV receiver. I'd like to buy another to hook up in my motor home. Because it is a motor home, I need to get a smaller speaker. How do I go about...
You can get wireless speakers from any of these stores
eBay.com, Amazon, com, Walmart.com, BestBuy.com and many other Hi-Fi Center
Hop this help you
Feb 10, 2018 | Audio Players & Recorders
Model No. TH-42PD50U can you hook ext speaker or wireless headphones?
Yes,if want to hook up ext.speakers.Buy the BOSE system,the best system out there so far.Wireless headphones.Buy the wireless headphone system.Plug in the remote stick to the HDMI hub and u have a wireless headphone.
Apr 28, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How to hook them up by the lake
By the look it is wireless. It should come with something to attach to the amp for the signal. It should work fine.
Jun 17, 2009 | Cables Unlimited 900MHz Wireless Rock...
Hook up brookstone wireless outdoor speaker
You cannot add other brand speakers to Bose systems. You must purchase the Bose second zone speaker amp and speakers.
Apr 26, 2009 | Bose (321GS) System
Hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Mar 24, 2009 | Sony STR-DE475 Receiver
Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
Feb 16, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Speakers stop working spontaneously
try and install the sound driver again this may help
Nov 21, 2008 | Audio Players & Recorders
Only one of my speakers work
Make sure the cable is all the way in and that your using the right jack. The green jack is usually the correct one. Make sure any other speaker wires are hooked up properly.
Oct 08, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Electronics - Others Logo
124 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
