Question about Whirlpool Dishwashers
We have a model DU8900xt- 2 dishwasher and the door now flops open without any gradual release. Is this fixable?
SOURCE: Door Drops Open - How to Fix
Actually the solution is quite easy.
First, get the door balance kit from ReparClinic.com mentioned herein. I believe it's Part #1059756.
Second, pull the DW out about halway from its recess (you may have to remove the two "mounting" screws where it is attached to the countertop.
Third, there are two door balance assemblies...one on the lower left side, one on the lower right side...where the door's fulcrum is (where it hinges). Each will consist of 2 pulleys, a string (with a plastic "latch" on one end, a plastic "loop" on the other), and a spring (near the back of the unit). One door balance assembly will likely be "good," one will be "broken," and the likely cause is the string has pulled from its "latch" end. Confused? Use the "good" door balance assembly for reference of how to replace the "broken" assembly. It's pretty straight forward once you compare the two.
Fourth, remove the "bad" assembly as needed. In my case, I only had to remove the string. The pulleys were fine.
Fifth, replace whatever parts you removed. In my case, I replaced only the string, but it required me to press it into the bottom pulley through the open guide at the bottom of it. In any event, replacing the string requires you pull on the string with sufficient force you can "thread" the string around the two pulleys, and hook the latch to the same location you find it latched on the other side of the door (there is a notch in the sheet metal).
Sixth, this is an optional step, but I did it so the string wouldn't pull out of its latch. Take a lighter, and heat the end of the rope in the latch (the part that's sticking out past the end of the latch). Heat it up until it begins to melt slightly, then press or ball it so it will not fray, or unravel enough to pull through the hole in the latch through which it is fitted. I don't know how they got that thing in there (I tried to put my old string back through), but it will likely find it's way out if it's left stock.
That's pretty much it. It's really not hard, and a set of instructions really aren't needed once you compare the left and right assemblies. One is almostly certainly still good, and "a picture is worth a thousand words."
Posted on Jul 01, 2008
e-Guru
  • 3917 Answers
SOURCE: Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Posted on Apr 24, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
Macmarkus
  • 2605 Answers
SOURCE: dishwasher door flopped open and
Hello, Welcome to Fixya.
Based on your description what you`ve likey experienced is a broken door closer/link kit.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit, and check the spring itself...that is seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Posted on Aug 02, 2010
SOURCE: dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
Posted on Aug 06, 2010
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
The spring came off the door. how do you put it back on it was on the side of the dishwasher.when you open it just flops down find the spring on the floor.do you have picture of where it goes
Remove the bottom toekick panel from the front of the dishwasher.
Look just inside and you will see spring mounting holes on the bottom support frame.
The spring goes from a hole to the hole in the lower door hinge.
If I had a model number I could be more specific.
Sep 14, 2010 | Maytag Dishwashers
I have no access to my garage and the handle to open it manually is not installed. the keypad and openers need to be reprogrammed but we have no access to the motor unit inside the garage. We are totally...
It is not fixable without access to the motor unit. There is a way to open the door but it involves drilling a hold and using a long tool to reach the manual release. A door opener technician can do this job.
Aug 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I want to fit a wooden door to a intagrated dishwasher stoves
If your dishwashermag-glass_10x10.gif door is not closing properly or has developed a leak, it may be time to replace the entire door assembly. Some other signs of a defective door include sagging, difficulty pulling the door back up into a closed position and a door that feels heavier as it drops open. Replacing a dishwasher door is not that hard, but includes several springs and hinges that must be aligned correctly or the door will not fit correctly in the opening.
  1. tep 1 Unplug the dishwasher and shut off the water before attempting to remove any parts. If you cannot reach the electrical outlet, you can turn off the breaker switch that controls the electricity for the kitchen. Remove the drain hose that runs from the dishwasher unit to the sink drain.
  2. Step 2 Pull the dishwasher out from the cabinet until you have clear access to the side of the unit. Ask a friend for help with this part if the unit is too heavy for you to slide out without straining your back.
  3. Step 3 Check your dishwasher's owner's manual to find out exactly how the outer door panels are removed. Some models have a two-panel door where the control panel must be removed before the lower panel will come off. Otherwise, the door panel should be one solid piece or a two-piece assembly that allows the lower section to be removed separately to access the springs and hinges.
  4. Step 4 Remove the springs at the bottom of the door. Depending on the type of dishwasher you have, there may be a tension adjustment dial or simply a series of holes at different distances from the edge of the unit. If you have a tension controller, adjust it to a loose setting to make it easier to remove the door springs. Unhook the door springs from the hinge plate. Some dishwashersmag-glass_10x10.gif may have a cable and pulley system attached to the door springs. Check your owner's manual for removal instructions if this is the case with your model.
  5. Step 5 Use pliers to gently pull back on the door hinge plate's tab until the slot opens for the hinge pin to come out. Take out the screws holding the door hinge plate onto the front of the door panel. Hold onto the door assembly while gradually opening the door. Once the door drops down, you should be able to remove it by sliding the door off the hinge pinAlways wear safety glasses when working with the springs and hinges involved with a dishwasher door assembly. These items can fly off at high speed and cause serious injury to the eye.
Nov 15, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
Feb 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Door won't open slowly
Hi barrianne,
I'm Harvey the Master Plumber.
You're asking: On my Kenmore elite, on opening, suddenly the door just slams to the bottom without the gradual opening that it had before. And you have to really close it -- previously it would stay ajar 2 or 3 inches but now it will open all the way. Whatever was holding the door up and not in the down position is now kerplooie. Any suggestions?
You're not alone! This is very common. It is usually easy to repair if you have the technical skill and tools to remove the d/w to allow access to the springs on each side and properly reinstall. I don't recomend it to the average homeowner.You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Dishwashers Logo
116 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
