Question about Linksys WRT160N Wireless Router
THE PRIMARY COMPUTER,THE ONE THAT IS WIRED DIRECTLT TO THE ROUTER IS THE ONLY COMPUTER IN THE HOUSE THAT DOESEN'T GET ONLINE. THE 3 WIRELESS LAPTOPS DO.HELP ME.DAVE
  • 57 Answers
Try using LAN ports on the switch and also known working CAT5 cable.
Check the IP address of your wired computer:
1. Click on start and select run then type CMD
2. on the black screen type ipconfig
3. check the IP address if it has 192.168.1.xxx range if yes, then it is communicating with your router
4. if not, ex. 169.xxx.xxx.xxx it means that it is not picking up an IP from the router so have the computer restarted.
Posted on Jun 24, 2009
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
I have 3 wireless connected and 1 computer that is connected via wired lan to this router. The problem is whenever I use the computer with wired connection, I computers with wireless connection cannot...
On the "wired" computer:
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Type IPCONFIG /ALL
Press Enter
Note the IP-address assigned to the Ethernet adapter.
Note the date/time at which the router assigned the IP-address to your computer.
Repeat on one of the "wireless" computers.
The IP-address should *NOT* match the IP-address of your "wired" computer, and the date/time should be close, but not identical, to the valuesl from the "wired" computer.
Any error-messages from the 'IPCONFIG /ALL' command?
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
I cannot connect to the other computer in the house. I do not know how to get to the configuations on my Linksys G router to ok the other computer.
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Mar 26, 2010 | Linksys Wireless-G WRT54G Router
Will not connect 2 internet
can u please elaborate on the problem .. like what is the kind of modem, how do u connect .. i.e using wired or wireless ... do you have any other pc in the house connecting
Mar 24, 2010 | Linksys Wireless-G WRT54G Router
My son's new Xbox Live cannot / will not connect with our wireless router, even though it recognizes it. I have a Belkin 802.11b
1) Get connected to belkin's wireless network or wired network
2) Once you get connected, it may not be able to go online on XBox Live
3) Go to any computer that is going online with the router
4) Type in 192.168.2.1 in the address bar of your Internet explorer
5) This will open up router interface(here we have to do some settings)
6) In the left hand side column, click on FIREWALL.
7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes.
8) Under FIREWALL(in the left hand side column), click on DMZ
9) Make a "check" on enable and under Private IP: 192.168.2.25. Click on Apply Changes.
10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration
IP: 192.168.2.25
Subnet: 255.255.255.0
Router: 192.168.2.1
11) Now select manual configuration for DNS settings.
Primary DNS: 4.2.2.2
Secondary DNS: 4.2.2.1
12) Restart both Belkin and Xbox
13) It should connect to XBox Live now...
Jan 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Need to restart wired computer to connect laptop to wireless router. wired computer is dell e520 using windows vista. router is linksys wrt54g ver 6.Laptop sometimes gets connected by another network, not...
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 27, 2009 | Linksys Wireless-G WRT54G Router
I am using linksys wrt54g2 V1 wireless router. The connection in wireless is fine. If I connect 1 wired coneection, it is still okay. But if more than 1 wired connection is used, all wireless connection is...
/Sometimes you have to call the cable company and they will reset the modem online for you. After you have done the whole powercycle bit, you have to restart the computer. Make sure all the other computers or laptops are shut off when you reset.
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters2.gif. Hope this helps!
Sep 18, 2009 | Linksys Wireless-G WRT54G Router
Wireless router - establish wired connection with desktop PC
You are right, cable connection is more secure. The steps are:
1.) Connect the PC to the router with a crossover cable.
2.) Once connected, try to see if you are in the network. If you are, then you are ready to connect to the net.
May 04, 2009 | Computers & Internet
Wirless router
nope...
your desktop can also go onlie using the wireless belkin router,so this router will now act as a distributor,you need to setup the router between the modem and the computer that is wired,i hope that when you say modem it is the one provided to you by your internet service provider,what you need to do is to conect the modem to the router and the router to you desktop computer,you desktop computer will go online using the wired connection to the belkin rotuer and you laptops will use the wireless connection..
vedhick
Feb 18, 2009 | Belkin (F5D7230-4) Router (587009)
New WRT54GS Router, Wired Desktop not working
To do this you would restor it back to factory which means old you programs and documents that have been added will be permatly lost inless you put these files on a usb flash brive or burn them to a cd.
Jan 04, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT160N Wireless Router  Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
