Faema Emblema Logo
A
Anonymous Posted on May 18, 2014
How to resset a faema emlema 4? - Faema Emblema
Can you help me fix my faema x30 coffee machine not heating one boiler thanks
Hey, Check the power supply and make sure it is connected properly before attempting to fix your Faema X30 coffee maker's non-heating boiler issue. Next, check for any flaws or malfunctions with the thermostat and heating element. If necessary, think about swapping out the defective parts or hiring a pro to fix it.Thanks!
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
1helpful
2answers
Repair heating element feama e97
Are you installing a new element or do you need to get a new one make sure you get an element gasket as well. Element is on right side of machine. Drain water 14mm plug under boiler. There are 4 wires on element two labeled 3, and one labeled 1, the other labeled 2. Element has 4 coils in two loops, top loop and bottom loop. 1 on top loop 2 on bottom loop the 3's on the other side.
Where do I find a group head seal for my Faema Contessa (family)? In the USA? Shipping from Austrailia is $30.00 and I would like to avoid that kind of charge if possible. I don't know the size of...
You ca get one from espressopartsNw.com of from cafeparts.com, faema uses the same parts for all their machines why reinvent the wheel, so the machine likely uses an 8mm gasket or the 8.5mm gasket.
2answers
I have a Faema special. model no.537212 I need the schematics
I have no clue about this product, but at the terminal board how many
wires come from machine to the board,or just wires coming from machine. A 220v, should have 2 hot, neutral,gr, so 4 wires. Depending
on what it looks like, the wires come from machine to a board or just wires.then the colors of those wires.
You should send them an email asking for help or schematic.
I posted there website below. Sorry could not help further.
http://www.faema.net/site/index.html
I would like to know a place where i could get the technical and part manuel of the following machine: ''FAEMA E91 A Diplomat'' And please if you can get it in french version it would be appriate thanks...
FAEMA COMPANY LTD. M6G 1Z6 Ontario and Western Canada ADDRESS _t.gif 672 Dupont Street, Suite 201, Toronto TELEPHONE _t.gif 001 416 535 1555 FAX _t.gif 001 416 535 3843 EMAIL _t.gif [email protected] _t.gif iko_piu.gif _t.gif FAEMA DISTRIBUTEUR, INC. QC H2R 2W5 Montreal, Quebec ADDRESS _t.gif 14 Jean-Talon West TELEPHONE _t.gif 001 514 276 2671 FAX _t.gif 001 514 276 5991 EMAIL _t.gif [email protected]
Top Faema Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
