Question about Acer Aspire 3000 Notebook
Acer Aspire 3000 recovery cd - Acer Aspire 3000 Notebook
SOURCE:
  • 244 Answers
SOURCE: Acer Aspire 5720-6438 recovery cd/driver cd
if you need drivers, you can download it from www.acerpanam.com.
for recovery cd, i don't think acer have it online, you need to order it from them.
FYI, if you haven't delete the partition in your hdd, you can use alt+f10 to re-install your Operating system and after that, you can create your own recovery cd.
Posted on Mar 22, 2008
  • 10 Answers
SOURCE: recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Posted on Jan 10, 2009
SOURCE: acer aspire 4315 recovery cd file...
all you need to do is go to Acer Empowering Technology (the e on the left side of keyboard) and then go to Acer Recovery Management
Posted on Jan 29, 2009
mahal1517
  • 62 Answers
SOURCE: Need Acer Aspire 5720G Recovery disk (CD)
visit the web site has> (http://www.acer.com)> to get what you need to recovery
Posted on Jul 22, 2009
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
Acer Aspire 3000 Help required to restore to factory
Acer does have a good support team, I think you would be further off getting the recovery disc, it comes with all the drivers eliminating guess work, and it is there if it is needed again.
Apr 01, 2012 | Acer Aspire 3000 Notebook
I have acer aspire 3002lci . I want restore factory settings. I won't have recovery cd.How to do? i had done with alt+f10 it doesn't work.
The ALT+F10 routine should work if the ALT key is held down and the F10 key is repeatedly depressed before and during the Acer logo display.
If you still have a working M/C then the recovery routine can be accessed from START / ALL PROGAMS and selecting Acer Empowering Technology and then Acer recovery Management.
This might differ a little because you have a netbook
Nov 07, 2010 | Acer Aspire 3000 Notebook
Boot sector
go 2 bios set up make your cd rom b the first bottable device.
Jan 28, 2009 | Acer Aspire 3000 Notebook
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
Jan 09, 2009 | Acer Aspire 3000 Notebook
Recovery cd for acer aspire 3000
Try the Following:
Jan 08, 2009 | Acer Aspire 3000 Notebook
I do have the cd
hi sir. do u have the xp cd..
Sep 08, 2008 | Acer Aspire 5100 Notebook
Acer aspire 3000
try booting the hard drive, and pressing F8 and booting to last known good configuration. If that doesnt work gheck out SUPER GRUB, it can fix your MBR if needed.
Jan 29, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3620 reformatting
You can download your driver here: http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
Just enter the model number of your stuff to driver list in PDF.
Jan 03, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
70 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
