1996 Jeep Grand Cherokee Logo
ladonna Posted on May 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel pressure 1998 jeep grand cherokee 4.0 L V6
Jayburt
Level 2:
Habit-Forming:
New Friend:
  • Expert 89 Answers
  • Posted on May 19, 2014
Jayburt
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
89
Questions
Helped
113375
Points
263
You should have a test port on the Fuel Supply rail, use a tool from a local auto parts "Tool Loaner program" where you can borrow tools for free,w/a deposit of course,then follow the steps provided;
MPI Fuel System Pressure Test
The MPI fuel system used in vehicles equipped with a 4.OL engine employs a vacuum balanced pressure regulator. Fuel pressure should be approximately 55-69 kPa (8-10 psi) lower with the vacuum line attached to the regulator than with the vacuum line disconnected. System fuel should be 214 kPa (31 psi) with the vacuum line connected to the regulator and 269 kPa (39 psi) with the vacuum line disconnected. CAUTION: Some fuel may be discharged when connecting fuel gauge to fuel rail.
  1. Connect a 0-414 kPa (0-60 psi) fuel pressure gauge to test port pressure fitting on fuel rail (Fig. 7).
  2. Remove vacuum line from pressure regulator.
  3. Start the vehicle.
  4. Note gauge reading. With vacuum line disconnected, fuel pressure should be approximately 269 kPa (39 psi).
  5. Connect vacuum line to pressure regulator. Note gauge reading. Fuel pressure should be approximately 214 kPa (31 psi).
  6. If fuel pressure is not approximately 55-69 kPa (8-10 psi) higher with vacuum line removed from regulator, inspect pressure regulator vacuum line for leaks, kinks or blockage. CAUTION: Fuel pressure will rise to as much as 655 kPa (95 psi) when the fuel return tine is pinched shut, shut engine down immediately after pinching oft fuel return line.
  7. If fuel pressure is low, momentarily pinch shut the hose section of the fuel return line. If fuel pressure remains low, inspect the fuel supply line, fuel filter, and fuel rail inlet for blockage. If fuel pressure rises replace fuel pressure regulator.
  8. If fuel pressure is above specifications, inspect the fuel return line for kinks and blockage.
Capacity Test
  1. Remove the cap from the pressure test port in the fuel rail.
  2. Connect a 0-414 kPa (0-60 psi) fuel pressure gauge to the pressure fitting on the fuel rail (Fig. 7).
  3. Start the vehicle. Pressure should be approxi- mately 214 kPa (31 psi) with the vacuum hose connected to the pressure regulator and 269 kPa (39 psi) with the vacuum hose removed from the pressure regulator.
  4. If the pressure is not to specification, check the following before replacing the fuel pressure regulator:
  • 4a - Inspect the fuel supply and return lines/hoses for kinks or restricting bends
  • 4b - Check the fuel pump flow rate. A good fuel pump will deliver at least 1 liter of fuel per minute with the fuel return line pinched off. If the fuel pump does not pump adequately, then inspect the fuel system for a plugged fuel filter or fuel pump inlet filter (sock). Fuel pump flow rate can be done by connecting one end of an old A/C gauge hose to the fuel test port on the fuel rail and inserting the other end of the hose into a container of at least 1 liter capacity. Run the fuel pump by installing a jumper wire into diagnostic connector terminals D1-5 and D1-6. Be sure to pinch off the fuel return line or most of the fuel will be returned to the fuel tank.
Accurate Auto Care
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
Accurate Auto Care
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
Helped
3971
Points
44
What's the issue with your fuel pressure?
Changing the fuel filter on a Jeep Grand Cherokee
most 2004-2007 Cherokees v6 and v8 models only had a strainer on the fuel pump jeep does make a replacement fuels line assembly with a fuel filter
1999 jeep grand cherokee laredo v6 4x4 won't fire on all 6 cylinders just 4 why?
Plenty of causes. Plugs, valves. rings, numerous electronic/electrical faults. Diagnose vehicle and eliminate problems one by one.
1helpful
Where is the fuel filter of the grand cherokee 1998
1998 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl the Fuel Filter is part of the fuel pressure regulator assembly which is located on the fuel pump module.The fuel pump module is located on top of the fuel tank.
Hope this helps (remember to rate this answer).
1helpful
04 jeep grand cherokee v6 - i was driving on the highway when the engine overheated and turned off and would not start until it cooled. what could be wrong or what could i check to find out? thanks
Hi.
Common fault is fuel pump getting damaged after engine overheating.
The pump is located in fuel tank, to know if pump is working, check fuel pressure using an hand gauge. It is available for $25 or so.
Check if there is coolant. If engine restarts check coolant level, if that goes down, then the head gasket has been damaged.
If fuel pressure is OK, check injection and distribution.
12helpful
Fuel filter location 1998 jeep grand cherokee loredeo
The fuel filter sits on top of the fuel pump. It is the fuel fuel filter/fuel pressure regulator. You will have to drop the gas tank to access it. Hope this helps.
Best of luck
Where is the fuel filter on a 1998 jeep grand cherokee
For 1998 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl the Fuel Filter is part of the fuel pressure regulator assembly which is located on the fuel pump module. The fuel pump module is located on top of the fuel tank.
Its possible that you are interesting in check the service manual ZJ-Secc-14-Fuel-System
Hope helps (remember rated this)..
1helpful
1993 Jeep Grand Cherokee, V6. Oil Pressure Gauge Read High.
it could be the sensor you should look at the oil pressure relief valve
WHEN MY JEEP GETS WARM AND I TURN IF OFF IT WONT START BACK UP
When this happens, have someone listen under the car and see if the fuel pump is coming on. Either the pump or relay may be going bad.
An easy check for the relay is to see if there are any non-essential relays with the same # on them (like a fan relay) when your'e having the problem, temporarily switch the two relays. If this helps, then replace the relay. Before condemming the pump, replace the fuel filter (often neglected), and do pressure tests at fuel rail to see what you are dealing with. Note: it does not have to be fuel... A bad coil or crank sensor can do essentially the same stuff so, don't jump to conclusions before making tests!
good luck
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
