Question about Haier HVFM20ABB Wine Cooler
Haier HVFM20ABB Wine Cooler water drips at bottom of door (sweat)
I have a new (1 year) Haier HVFM20ABB Wine Cooler.
Every day (sometimes twice a day) a small pool of water forms on the floor under the corner of the door, and when I open the cooler, a line of water leaks out matching the arc of the door. I'm guessing this is mostly due to sweating, and when the atmosphere is more humid, there is more water.
But is this a problem that can be fixed?
  • 833 Answers
SOURCE: Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Posted on Dec 21, 2007
SOURCE: haier wine cooler
Hold + and - keys down together until LED blinds (about 4 or 5 seconds), Then press + or - key to lower or raise temp. Once you've reached the desired temp press the set key.
Posted on Mar 18, 2008
  • 171 Answers
SOURCE: Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: HAIER WINE COOLER HVW18bss I
IS THERE A THERMOSTAT YOU CAN JUMP OUT WITH A SMALL PIECE OF WIRE?IF THAT DOES NOT WORK A THINK YOU HAVE A LEAK SOMEWHERE,CHECK ALL THE PIPE CONNECTIONS TO SEE IF YOU SEE ANY OIL,LET ME KNOW-MIKE
Posted on Sep 21, 2008
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
Ice build up
Normal to have a bit of ice. Set the temp to 0 for a few hours every week. Check Seal is good all round the door.
Apr 20, 2014 | Haier HVFM20ABB Wine Cooler
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
I have a HVFM20ABB wine cooler and the unit is not getting cold. Is there step or items on the cooler that could be checked to see why it isn't geting cold? There is a noise that it makes when it is on,...
rer
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Haier HVFM20ABB Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Clicking sound and not cooling
compressor grounded. replace relay or compressor
Jan 02, 2010 | Haier HVFM20ABB Wine Cooler
Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
Aug 25, 2009 | Haier HVFM20ABB Wine Cooler
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Magic chef wine cooler
That means couple of things. The cooler's glass door is poorly insulated, and the cooler is placed in a humid environment. To eliminate the sweating you can run a dehumidifier close to the cooler, or you can insulate the inside of the door with styrofoam but that's going to spoil the look of the cooler.
Aug 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Haier HVFM20ABB Wine Cooler Logo
122 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
