Question about Orion HCCA 225G4 Car Audio Amplifier
2 of the ndp-7060 transistors blew up, i replaced them and its still overheating
Are you using the right gauge power wire and are your ohms correct
Posted on Jun 24, 2009
Overheating
About the only thing left is the water pump.
Mar 29, 2014 | Mercury Villager Cars & Trucks
MY RADIO BLEW UP ONE OF ITS TRANSISTOR B..something please help me to know the other digits for thew repair
Transistors have their type written on them in very small print.
Look at the transistor that is faulty and read off the number printed on it.
Dec 19, 2013 | Philips AZ2555 CD Boombox
On my kenwood VR-5900 twospeaker wires touched and the reciever clicked off now when you turn it on it comeson for a sec. then clicks and shuts off. none of the fuses inside areblown what could be the...
When the two wires touched the short overheated and blew the output transistor or transistors. The unit needs to be repaired or replaced. It only takes a momentary touch of the wires to blow the output transistor. It is not a fault of your particular amp. It is common to all Solid State amps. Tube amps that have output transformers are not susceptible to this problem. Always shut off the amp when connecting or disconnecting the wires.
Oct 29, 2013 | Audio Players & Recorders
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
No power fuse blew
it means you have shorted regulator transistor on power supply..
It is usually fit in heat sink..
Try to replace it and the fuse again also check any fusible resistor near that transistor..
Feb 23, 2012 | SNK Magnavox 32MF338B27 32 in. LCD TV
Our Magnavox MWR20V6 will no longer turn on. We replaced the fuse inside and it blew out as soon as we turned on power. The power cord, all inside leads, and components look fine. What usually goes with...
there is a diode or transistor that is defective. that is why the fuse keeps blew out. on visual the components looks fine but if you check the diode or transistor components they are so called open or defective.
Mar 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Blew radiator hose, overheated, Hose replaced,
Did the inside of the distibuter cap get wet? If so dry it out and it should start.
Oct 03, 2009 | 1996 Jeep Grand Cherokee
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Looking for bulb for marvin heater
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95.
You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Feb 27, 2009 | Marvin 7060 Utility Heater
Pioneer m-770 will not turn on
you probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Dec 24, 2007 | Audio Players & Recorders
Orion HCCA 225G4 Car Audio Amplifier Logo
188 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Mark Skinner
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
