Brookstone SmartSet® Clock Radio Logo
Bill Monk Posted on May 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I adjust the snooze setting on my smartset clock radio?
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on May 19, 2014
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
955928
Points
10318
tip
Daylight Saving Time Changes for SmartSet Clock/Radios
Dear Emerson SmartSet® Clock/Clock Radio Owner:
Your Emerson SmartSet® Clock or Clock Radio includes Emerson’s patentedAuto Time Setting System that
automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and
after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and
alarm settings for up to 5 years, or even longer.
As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/
Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into
all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight
Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April
and ends on the last Sunday in October.
The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to
extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in
March and end on the first Sunday in November.
Of course this is a situation that is beyond the control of Emerson, or any other company that produces
devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA’s, and
many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to
make adjustments to the automatic DST software to agree with the new DST timing for 2007.
Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It
would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows:
1.) On the second Sunday in March you would have to set your clock to the next lower number time zone.
For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone
1 to move it ahead by one hour.
2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the
clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set
your clock back to Zone 02.
3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone.
4.) On the first Sunday in November you would again set your clock back to your correct time zone.
Instructions for changing the Time Zone setting are found in the Owner’s Manual.
We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Printed in China
508-02
I have 2 Emerson Research SmartSet Clock Radios-1 is 2 mins slow the other is 10 mins slow. Is there a method of correcting the problem? Alan Loso
There is a process by which you can adjust time on all clocks. Please use that. It should be depicted by "Set". Select this followed by "Time". The numerals will start flashing. Then you can use the + or - buttons to adjust the time.
2helpful
Snooze doesn't work anymore
1.You will need to reset the microprocessor of the Clock/Radio. To do this you must unplug the Clock/Radio and take out the internal battery. You must let the Clock/Radio set unplugged and with out the battery for at lease 1 hour. Then replace the battery and plug in the Clock/Radio and see if the functions return to normal.If not try replacing the internal battery (CR2430) and leaving the Clock/Radio unplugged for a few hours. Then put in the new battery and Plug in the Clock/Radio and see if the functions return to normal. If not you may have other problems with the microprocessor. You can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. 2.http://www.emersonradio.com/dst.htm Copy this web link and paste it into the address bar of your browser. This will take you to the Emerson customer support web page. This page has the procedure for setting the day light saving feature in your Clock/Radio. I hope this information helps you with your problems.
1helpful
Snooze -- NO
sounds like it is working. shut off sensor if you want snooze to work
2helpful
Emerson smart set clocks
Sorry it took so long to give you a answer to your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day! Dear Emerson SmartSet® Clock/Clock Radio Owner: Your Emerson SmartSet® Clock or Clock Radio includes Emerson?s patentedAuto Time Setting System that automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and alarm settings for up to 5 years, or even longer. As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/ Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April and ends on the last Sunday in October. The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in March and end on the first Sunday in November. Of course this is a situation that is beyond the control of Emerson, or any other company that produces devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA?s, and many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to make adjustments to the automatic DST software to agree with the new DST timing for 2007. Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows: 1.) On the second Sunday in March you would have to set your clock to the next lower number time zone. For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone 1 to move it ahead by one hour. 2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set your clock back to Zone 02. 3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone. 4.) On the first Sunday in November you would again set your clock back to your correct time zone. Instructions for changing the Time Zone setting are found in the Owner?s Manual. We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
How do I set the sleep timer?
To adjust snooze time - The system is set for a standard 10-minute snooze time (the number
of minutes you can delay the alarm). While the selected alarm is flashing, hold down Sleep⁄Snooze
and press the Time or to adjust the snooze time (from 1 to 30 minutes) for that alarm. The
number of minutes and Sn appear on the display to confirm your selected snooze time. You can
set a different snooze time for each alarm.
9helpful
Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
2answers
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
3answers
There was a sheet of paper that came with my clock explaining how to adjust the daylight savings time settings, but I lost it.  Anyone have theirs?  All i know is it requires that you press an awkward combination of buttons simultaneously, but that's it.
Top Brookstone Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
