Question about Air Tools & Compressors
Water sprays out sides of tip on all three tips.
When installed the tip is still loose and spins.
  • 508 Answers
Most likely missing o-ring or obstructed not tightening all the way!!!Good Luck!!!
Posted on Jun 24, 2009
Troy bilt pressure washer 2550 psi 6.25 hp. we borrowed from my brother and it doesn't have full pressure coming from the nozzle because there is water steadily coming out of the side from a sun shaped...
There is a valve installed to release water out of the system if water temp. rises to a level that may damage the pump. Water temp will rise when motor is running and you are not spraying water. This part is called a thermal valve. It can begin to leak water if worn out or debris under seat, however may not effect a lower pressure at the wand unless it leaks more water when you are spraying than when in bypass. You can see various thermal valves by searching on ebay with the key words :
"pressure washer thermal valve". Pressure is created at the tip of the wand. If the nozzle at the wand is worn or too large for the system, pressure will be reduced. You can check if the tip is correct by using a different tip that came with your system or using new of correct gpm as noted on the specs. of your system. Good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
May 28, 2011 | Bissell 1716 Spot Lifter PowerBrush...
Trying to troubleshoot kenmore dishwasher. water is coming in and out like it's supposed to. doesn't look like the spray arm is spinning although water comes out. help!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 28, 2011 | Kenmore Dishwashers
Top spray arm won't spin. No clogs. Water runs fine. Arm just won't spin. Will spin freely if I move it
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 18, 2010 | Kenmore Dishwashers
Kenmore 18 in. dishwasher is not spraying water and the sprayer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 25, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
My pressure washer will not pump the soap, when you take the pipe loose from the handle it pumps out when you hook it back to the handle it quites pumping
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
Sep 02, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
My dishwasher sprays water up into the dishes but the little spray arms don't move when the water sprays up. The arms move by hand when I touch them. What could this mean for my dishwasher?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
heatman101
Aug 31, 2010 | Whirlpool Dishwashers
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
