I am unable to loosen the spindle that appears to be frozen in order to change the washer. It has not been loosened for a number of years and I am worried that if I apply too much pressure that it could snap off inside the wall.
How To Remove Bathtub Faucet Stems
Yes, faucet stems can be very difficult to loosen after years of mineral buildup. First you want to make sure the valve is open half way. Spray the stem nut with a lubricant such as WD 40 or the like.Let the lubricant work its way inside the threads. You may also use a heat gun or hair dryer to heat up the nut a little. Keep trying to loosen the stem ( a stem socket should be used). Keep spraying the stem nut. Try to go the other way, to tighten the stem, but do this on the gentle side. Do not put much pressure on the turn. It's a matter of a little at a time, as with a frozen nut on a bolt. Good Luck!!!
