Question about Amana ARSE66MB Side by Side Refrigerator
Freezer defrosts too much
Freezer defrosts to the point that everything in it melts. Happens once in a while. Everything refreezes afterward.
  • fixya269 Jun 24, 2009
    That might be helpful if I knew what / where a termination switch is. ;)
  • 351 Answers
I wonder if there is a loose wire on the termination switch
Posted on Jun 24, 2009
  • Mark Nichols Jun 24, 2009
    it is behind the evaporator coil cover in the freezer usually top right corner size of a quater and about 1/2" thick
Freezer freezes but at some point thaws and then cools again. So everything is melting then freezing again; ice cubes melt and drip then refreeze.
The auto defrost timer may be broken. The freezer is going for a too long time in the heat cycle. Also ice can be stuck behind the cooling circuit and the cold air is not circulating well. Check if water is going in the evaporating pan at the bottom of the fridge. It should have a little water everyday.
Oct 11, 2016 | Whirlpool Refrigerators
My freezer is defrosting and melting the ice then refreezing so that all the cubes are frozen together. How do I fix this?
check ur thermistors for ohms and amount of current being put out? then check ur defrost timer and cold control thermostat
Feb 25, 2015 | Refrigerators
Model #970658324 leaking water from the freezer to top shelf of frig once a week probably with defrost cycle. Help!
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Kenmore Refrigerators
Ice build up in bottom
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Jun 03, 2012 | Amana Refrigerators
Blocked freezer drain
May 28, 2012 | Refrigerators
Fridge icing up
If your machine is a side by side
If your machine is a top mount meaning that the freezer is on top
May 17, 2012 | Fisher and Paykel Refrigerators
Freezer defrosts, things melt then frost up
You have a defrost system failure. You can verify this by take off the rear shield of the freezer and looking at your evaporator coil. If it has a large amount of ice built up on it, then your defrost circuit is not functioning. The defrost circuit is made up of the heater (WR51X10055), the defrost thermostat (WR50X10068) that are located in the freezer section close to the evaporator coils and a timing circuit that is part of the main control board (WR55X10942) which is located in your component compartment at the lower rear.
NOTE: If you defrost the evaporator coils the refrigerator should operator normally for about two weeks (until the ice builds back up).
Hope this helps! Hal aka ImJustAvg
Jan 01, 2012 | GE Americana A4425GDTWW Side by Side...
My freezer gets ice buidup
If it's on the surface of all the food it may be caused by leaky door gaskets or frequent door opening.
If it's on the back wall..
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Refrigerators
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
Amana ARSE66MB Side by Side Refrigerator Logo
108 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
