Question about HP PSC 950 All-In-One InkJet Printer
Plz Help my Printer
Hello, I have had my printer for a few years. In the past month or so I have had numerous difficulties. First before I print anything I have to turn off then on. It then only prints two pages of my print The printer keeps saying to allign the ink cartriges. We have done all the steps you have reccemonded and it still fails to work properly. We are however recieving faxes.
Thank you
  • 57 Answers
I understand that you are receiving the message to align print cartridges when ever you print.
This happens due to various of reasons.
Below are the possible causes of the issue that you are experiencing with.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
So, make sure that ink cartridges have sufficient amount of ink and are of genuine HP should not be refilled or remanufactured.
Clean the cartridges by following the below given instructions:
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Align the print cartridges by following below given instrucions:
To align the cartridges from All-in-One
1. Press Setup.
2. Press 5, then press 2. This selects the Maintenance menu, then selects the Align Print Cartridge option. A page prints to confirm alignment. You can either discard or recycle this page.
Even if the issue persists, bypass the alignment by following the below given instructions:
Press Enter and Setup simultaneously when align message is prompted on the All-in-One.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
This should resolve the issue.
Posted on Jan 12, 2008
2 Suggested Answers
  • 188 Answers
SOURCE: Messed up printer plz help
Please click on the web link given below and perform the steps as provided in the web page to fix the issue further.
Have a great day!
Posted on Apr 02, 2008
Hello, my canon ip4000 just won't print properly. i have been executing "deep cleaning" numerous times but the print out still has missing lines. i sent it to our local canon service center...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 24, 2011 | Office Equipment & Supplies
Hello, I bought a printer a few months ago but it doesn't seem to work. I've installed the proper drivers but every time I try printing sth a got a message ''Service error 5100, cancel printing and then...
I could make several suggestion to "fix" the problem, such as clean the timing strip, etc., but since your printer is still under warranty, I'd suggest contacting Canon for a repair / replacement due to a potential hardware problem. You shouldn't be getting a "Service error 5100" after a few months.
Hope this helps.
Nov 24, 2009 | Canon Pixma iP4500 InkJet Printer
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
1200 series lexmar printer
My printer won't print neither black or color cartridges; it marks that it had 75% ink
remaining. How can You help me to find out what is the problem if is the printer or the
cartridges. Its been a year I bought the printer but it was in storage around 6 months.
I would appreciate if You can find the problem and the solution.
Thank You for your time.
Feb 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Have a great day!
Oct 31, 2007 | HP PSC 950 All-In-One InkJet Printer
Test page
try with replacing the catridge or clean with tissue paper and do the test page scan again
Sep 06, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
106 people viewed this question
Ben Johnson
