Question about Belkin Electronics - Others
What is correct AC adaptor for a Belkin USB Pocket Hub F5U007?
I have a Belkin USB Pocket Hub F5U007 and misplaced the AC power supply. It works fine for some devices but needs external power for others .
I have several AC adaptors and one of them might be the proper one but I can't recall,so I hope someone knows what is the proper voltage/amperage to use without causing damage.
Thanks for your help.
    Problem Solver:
  • 11 Answers
AC Adapter (100-240V, 50/60Hz)
Posted on Jun 25, 2009
  • Brax Jon
    Brax Jon May 03, 2015
    Target doesn't even have the power adapter!
    New Friend:
    Problem Solver:
  • 8 Answers
A link to Target? You call that an answer? Well in case anyone else might need this info, here is the RIGHT answer:
The power adapter included with the hub is a L.S.E. LSE9801B05 (USA) (100-125VAC ~ 50/60Hz, 0.6A -> 5VDC 3A).
Posted on May 03, 2015
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
I have a Q-Stor 7 port USB hub, Model QU2RCT7. I
I don't have the original power supply for my QU2RCT7 either, but most hubs use a 5v DC power adapter, typically with a 2A. (2 amp) rating. I'm using such an adapter with my QU2RCT7 and it works fine. Make sure the adapter you select is tip-positive (ie, the "+" terminal is the "tip," or center, of the connector).
Sep 14, 2009 | QPS (QU2RCT7) 7-Port USB Hub
USB hub not working?
When you get USB devices, some have their own power, like a plug-in hard drive, and some get their power from the host, like jump drives. My USB scanner gets power from the host, but if you plug it into a USB hub, it sucks the power from the host. Too many of those devices and the scanner fails, so they suggest you don't plug it into a hub.
Here's where the BUS and SELF switch come in. Somewhere, there is a 6v DC power supply that either came with your Belkin or is optional. If you use it, and put the switch on SELF, you don't have to worry about what you plug into the ports. If you don't care, or don't have the power supply, you can put the switch on BUS, but be aware that not all USB devices you plug into the hub will work, or a combination of two devices may not work.
Carl
May 20, 2009 | Belkin ExpressBus (F5U021) 4-Port USB Hub
Entrega Hub 4U
The adapter that works on my machub4u y Entrega Technologies has a output of +5VDC at 2.5A with the inner post being positive and the barrel being negative.
Sep 01, 2008 | Entrega (HUB-4U) Networking Hub
Wireless USB adaptor not found
Hi zlyman, The Belkin N1 Wireless USB 2.0 Network Adapter might be choosy with what motherboard it is attached to. Pls refer to this similar problem > http://www.fixya.com/support/t201253-not_identify_belkin_n1_wireless_usb Hope this be of some help/idea. Post back how things stand or should you need further information. Good luck and kind regards.
Oct 02, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Electronics - Others Logo
851 people viewed this question
Top Belkin Electronics - Others Experts
Marvin
Marvin
Are you a Belkin Electronics - Other Expert? Answer questions, earn points and help others
