Question about Motorola Mobility MOTOFONE F3 + 10 Virgin Credit Cellular Phone
My motofone f3 went into silent mode, even i increase the volume to 5 level the sound is not coming, after 5 if i press more it is going to vibration mode, could u please help me to get the ringing sound
YOU CAN TURN SILENT MODE OFF BY JUST PUSHING THE UP ARROW FROM THE CLOCK SCREEN AND HOLDING IT DOWN UNTIL IT RELEASES SILENT MODE. TO TURN SILENT ON JUST DO THE SAME PUSHING THE DOWN ARROW.
Posted on Aug 11, 2009
Why is it when people call me my iphone 5 does not ring, how can i make it ring?
check the left side of your iphone and see if the ringer button is down then raise it up and increase the sound volume. Or go to settings then sounds and check the sound level. Else try to restart your iphone if it doesn't work then the problem might be in your iphone speaker.
May 28, 2014 | Apple iPhone 5
I don't want my phone to be in silent mode!!! Help!
To turn off the ringtone:
Press and hold the Power key on the top of the phone, then tap Silent mode.
Press and hold the down the Volume key until the volume bar is empty and the Ringer volume icon has a x next to it.
To set the vibrating alert:
1.From the Home screen, find and tap Settings.
2.Tap Sound & display.
3.Mark the Phone vibrate checkbox.
Tip: When in silent mode, press the Volume key up once to activate the phone vibrate mode.
Do the opposite to turn it back on.
Jul 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My phone has a very low sound that i cannot even hear it when it is in my pocket.It does not even vibrate in such a way that i can detect it.
you can increase the sound level,
the sound level for tones, speaker fone, etc,
can be increase even then if it is at max (level 4)
you still can do it,
just follows the instructions!
**************** HERE WE GO **************
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
IF U R SATISFIED PLS VOTE ME
Jan 21, 2010 | Samsung SGH-E370 Cellular Phone
How do I put my lg neon on silent mode without going through the menu and changing the ringtone? I can't find it anywhere
i figured out how. on the volume buttons (on the side) you just keep pressing the down button even after it says vibrate., if you press it enough (consecutively) it will say silent all
hope that helped
Jan 03, 2010 | LG Neon GT365 Cell Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
My phone is on silent mode, how do i get it back to ring mode?
Go to your sound option under settings, and there should be an option for SOUND, you should be able to increase, the volume there, Let me know how it goes, thanks
Justin
Please Rate Me :)
Jan 16, 2009 | Nextel i836
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Motorola Mobility MOTOFONE F3 + 10 Virgin Credit Cellular Phone Logo
557 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
