Question about Maytag Dryers
I have a Maytag Dryer, model LDE 313, series 03, which is over 15 years old. It works but it never stops and does not dry the cloeth, no hot air. What could be the problem?
jonniewalker
  • 1031 Answers
SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Posted on Feb 21, 2009
  • 7 Answers
SOURCE: Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Posted on Jul 15, 2009
Healeyman
  • 1198 Answers
SOURCE: maytag dryer lde 313
Check the belt.
Posted on Apr 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: Why is my maytag dryer Model DE382, Series 07 not
Have you checked the heater? This is a fairly easy fix.
Remove the 2 screws at the base of the dryer and take the front panel off (after turning power off), The heater and safetys is right there on the floor of the dryer. Get a meter and check the components and heater. You can restring the heater, no need to buy the whole "mailbox ".
Some repair photos: HERE
Let me know what you find out; if all of that is good you could have a problem with the timer or the heat control.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 31, 2009
wiringlunati
  • 576 Answers
SOURCE: Maytag Dryer Model #LDE 4916 ACE. Dryer won't start
Sorry, no reset button. If it ran a bit without the belt, it may have overheated and blown one of the thermal fuses. You can find schematics and diagrams at
www.appliancepartspros.com
Good luck.
Posted on Mar 15, 2010
Maytag quiet series 300 manual
pf is power failure because you unplugged it,is it gas or electric,that could be anything,you need to open the door,look around the opening and find the model number and send it,if it is gas you could have bad gas coils located on the gas valve,they will work for the first 15 to 20 minutes and when they heat up they will fail only if they're going bad so the clothes will feel warm but not dry,also you still could have a block in the vent line or in the duct where the lint filter slides into,there's a blower wheel in there that blows the air around,remember all a dryer does is move hot air around to dry the clothes,the easiest way to check the line is to remove it from the back and run it,but first clean out where the lint filter slides into
Oct 01, 2017 | Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
Timer no longer works.
IT IS NOT RECOMMEND BECAUSE OF DAMAGE OF MOTOR, BUSHING, ETC!!! IT IS BETTER TO BUY A NEW ONE!!
Oct 05, 2009 | Dryers
Jul 15, 2009 | Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Maytag model
You really need a volt / ohm meter to check for Continuity & VoltsIts well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity they have to be replaced
Oct 11, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
106 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
