Question about Panasonic KX-TG9341T Cordless Phone
No dial tone and no incoming voice when press on talk button; but when press on speakerphone everything works well; can hear the dial tone, and the incoming voice through the speaker phone;
  • 69 Answers
Might want to check the handset volume .....
Posted on Jun 24, 2009
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
Phone won't dial out
I have a GE 6.0 cell fusion phone, Model# 28128. It doesn't give a dial tone. So we cannot make or hear any calls. The incoming calls go to voicemail. I used to power off and on to solve this problem, but that temporary idea does not work. Please help.
Any ideas?
Apr 08, 2010 | Uniden Cordless Phone
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
Your HP all-in-one provides three levels for adjusting the ring and speaker volume.
The ring volume is the volume of the phone rings. The speaker volume is the level of
everything else, such as the dial tones, fax tones, and button press beeps. The default
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My blitz's speaker phone wont work. and the open/close, on/off, and ringtones, wont work... help! ive gone thru all sound settings and everything is "on" i can hear my calls thru the regular handset...
Try these couple of things:
The speakerphone feature lets you hear audio through the speaker and
talk without holding the phone.
  1. To activate the speakerphone while in answering or calling modes,
    press the Navigation Key to the right.
  2. The phone returns to normal (Speakerphone Off) after ending a call
    or when the phone is turned off and back on.
To adjust the ringer, key tone, voice call and speaker phone volume levels:
1. Press left soft key [MENU] (7) (1) (2).
2. Select the type of volume you wish to adjust.
3. Select the desired volume level.
4. To confirm, press OK.
Let me know if this works for you or if I can help you with anything else.
JimmyC
Jun 13, 2009 | UTStarcom Blitz Cell Phone
No tones, just a click when dialing
Try setting it on pulse, then hear it click when you push the number, if it works switch it back and try agian
Mar 05, 2009 | Panasonic Lands Phones
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Panasonic KX-TG9341T Cordless Phone Logo
469 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
