Print cartridge nalignment failure - Office Equipment & Supplies
    President:
  • 1,996 Answers
For HP, go here, enter model, choose solve a problem.
Otherwise, what printer make and model#?
Posted on Jun 24, 2009
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
I can't seem to install my ink cartridge correctly. Do you have a picture demonstration on how to do this? I continue getting an error message.
Installing the print cartridges Follow the instructions below to install the print cartridges: caution.png CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  1. Remove the print cartridge from its packaging and carefully remove the plastic tape from the copper strip. Figure 2: Removing the plastic tapec00109809.jpg
  2. With the power on, open the printer's top cover. The cradle moves to the center of the printer.
  3. Hold the print cartridge so that the copper strip is on the bottom. Figure 3: Holding the print cartridgec00109811.jpg
  4. Insert the cartridge into the cradle at a slight upward angle until you feel resistance. Figure 4: Inserting the print cartridgec00109813.jpg
  5. Firmly push the cartridge into the cradle. You will hear a snapping sound when the print cartridge is correctly positioned. The print cartridge fits securely in its cradle. Figure 5: Print cartridge in correct positionc00109815.jpg
  6. Close the top cover.
  7. Calibrate the printer for optimum print quality.
    Best of luck!
Sep 06, 2011 | HP Office Equipment & Supplies
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
I have an HP D4300 printer/scanner and I can't figure out how to open a in order to change cartridges. Please advise.
Installation instructions
Always install the tri-color print cartridge in the left side of the print cartridge carriage.
Install the black or photo print cartridge in the right side of the print cartridge carriage.
To replace a print cartridge
1. Verify that the printer is turned on.
2. Load Letter or A4 plain, white paper in the paper tray.
3. Open the printer cover.
Chapter 10
64 Maintenance Maintenance
4. Wait until the print cartridge carriage moves to the right side of the printer and is idle
and quiet.
5. Press down on the print cartridge, and then slide it out of the print cartridge carriage.
6. Remove the replacement print cartridge from its packaging and carefully remove the
1 Remove plastic tape
Install print cartridges 65
Maintenance
7. Slide the print cartridge at a slight upward angle into the carriage until the cartridge
snaps into place.
Align print cartridges for optimum print quality.
For information about storing print cartridges, see Maintain print cartridges.
For information about recycling empty print cartridges, see HP inkjet supplies recycling
program.
WARNING! Keep both new and used print cartridges out of the reach of children.
Download manual for proper guidance. http://h10032.www1.hp.com/ctg/Manual/c01438085.pdf
I hope this works for you. Goodluck!
Mongkey
"Understanding explains better..."
Jan 22, 2011 | HP Office Equipment & Supplies
HP970cxi 'pen failure' problem
From what I've read, it seems that a "pen failure" is a cryptic message to indicate a cartridge failure. Replacing your print cartridges should solve the problem.
Jan 20, 2010 | HP DeskJet 970cxi InkJet Printer
Printing with generic cartridges
Lexmark International does not recommend the use of third party inks or inkjet cartridge refill kits. Genuine Lexmark inks and cartridges are perfectly matched to the printing system. Using genuine Lexmark ink and cartridges ensures that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer.
Lexmark cannot assure the excellent print quality and reliability of its inkjet cartridges after a cartridge has been refilled. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Inkjet cartridges and printer failures caused by refilling or a third party ink are not covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
Please use genuine Lexmark cartridges for best results.
Apr 20, 2009 | Office Equipment & Supplies
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Nov 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
k24674
jasbo
jasbo
Marvin
Marvin
