I have a Mitsubishi WD-62525. The power went off in a storm and now the power/timer light is blinking fast and nothing else will hapen. For the life of me I can not find my owners manual. I have tried disconecting the power and using the reset button to no avail.
I tried replacing the dm caps. and that doesn't work. any other ideas???
Posted on Jun 24, 2009
  • 8,617 Answers
Commom problem the DM capacitors have failed. Here is the repair kit for your model which contains the parts with detailed instructions
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
After a power outage my wd62525 won't restart.......the green timer light has been blinking for more than 24 hours HELP!! (I did try to reset, same blinking)
There is chance that the power outage might have damaged the power supply. It does happen, it's most common with storms. I recommend that you go to a shop and get that board checked
Dec 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My wd 62525 has a blinking timer light and wont power on
do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Nov 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green timer light blinks fast after power loss
If this is a Mitsubishi you have a problem on the dm board, if it is a wd series there are some capacitors that buldge on the top that can cause this, if it is a ws series then you usually have to have the dm board replaced.
Aug 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
