Question about Chaintech 9CJS ZENITH Motherboard
Power on intermittant
Power supply will not turn on afterafter a change in the AC line cord. A few days later the unit turns on normally. I never know if or when the computer will turn on after i shut down
  • 2,404 Answers
I've ran into this before with computers turning on sometimes and other times not turning on. Sometimes even totally dead computers.
Her is what I would suggest.
Get a known good working power supply and try that and see if that takes care of the problem. It can possibly be that there might be some bad capacitors in the power supply that are faulty enough to cause intermittent problems.
If that doesn't take care of the problem then go ahead and reseat the CPU and memory as this can cause problems like this as well.
Also if this doesn't work, only hook up the power to the motherboard, meaning the main connector and the p4 connector. Try turning it on and do this a number of times and see if you can get the machine to turn on and off the way you want.
If you can then you know its another component that is causing problems, and at that point it could be the hard drive, dvd drive or any other pieces of hardware thats in there.
If you can't get the computer to turn on the way you want even just hooking up the bare minimums then the motherboard is going bad on you.
Posted on Jun 24, 2009
2012 Equinox the ac fan works intermittemtly. Blows ok for days then nothing. What are the likely problems. The ac line is cold so compresdor seems ok.
The A/C line's , the compressor etc. wouldn't have anything to with the blower motor working intermittently . electrical power supply problem . Looking at wiring diagrams to see what all is involved in making the blower motor work would be the first step in diagnosing the problem . Knowing GM vehicle's i would say the blower control module is starting to go bad . GMC Yukon HVAC Blower Motor Won Turn On This is the same on your chevy .
Jun 10, 2018 | AC Cars & Trucks
Power to instrument panel, door lock, AC went on/off during driving
It appears that you have a bad intermittent connection and those are hard to fix because most of the time, like when you want to work on it, everything is fine! But yes, check the wiring and the switches involved in affected circuits you described.
Sep 13, 2015 | 1998 Toyota Camry
Tv randomly shuts off. Not sure if it is just overheating or if it is broken.
It sounds as if you are having problems with the AC Power reaching the television. Please verify the cord is firmly seated the tv's ac inlet
Also check the wall outlet (and power strip) by plugging in a lamp into it and see if it flickers when the tv shuts off.
Good Luck!
Rich Lilja
Mar 21, 2015 | Insignia NS-32E740A12 32" Class LED HDTV
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
SR1000T won't power on
The click sound is the relay clicking when the power on. The power supply has something wrong so the protection relay is triggered and cut off power to main board. Test fans see if they are stucked and spinning smouthly. Smell if anything burn from the power supply box. Most likely, you need to change the power sup. Good luck
Aug 11, 2009 | Compaq Presario SR1000T (568657) PC...
Dell inspiron 5150 do not come on when the power button pressed
If you remove the battery and disconnect power cord, then hold power button for 20 seconds, then reconnect power cord but do not re-insert battery, and the unit powers on okay, the problem may be your battery. If there is still an intermittent problem, the power connector inside the unit may be loose and need re-soldering, or you could have a bad power supply.
May 17, 2009 | Dell Inspiron 5150 Notebook
My asus laptop cant turn on
you need to replace the Power button...
Apr 12, 2009 | ASUS AC Adapter- Universal Notebook AC...
Printer
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Aug 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
Mx35 no power
Hi, can you use a multimeter? If so then check on the power suply what the voltage output should be for that unit. Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have. If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit. Regards mistyman
Sep 01, 2007 | Toshiba PA2502U - Libretto 100, 110,...
Chaintech 9CJS ZENITH Motherboard Logo
69 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
